11-13-2015, 04:00 PM | #1 |
BimmerPost Supporting Vendor
24206
Rep 190,807
VRSF Intercooler Now Available for the F Chassis !!!
The VRSF FMIC was designed to be one of the best performing direct bolt on intercoolers available on the market. The VRSF intercooler features 3D CAD designed cast aluminum end tanks for improved flow over sheet metal end tanks & durability. We use a custom bar & plate intercooler core and a custom fin pack designed to our exact specification which we've developed over the past 10 years with multiple record breaking applications. VRSF Upgraded Stepped Intercooler Kit - 2012-2015 BMW 228i/M235i/328i/335i/428i/435i N20 & N55 Replace your inefficient factory intercooler with the VRSF upgraded intercooler kit to get the most out of your N20/N55. We designed this kit to be one of the best performing, direct bolt on intercoolers available for your BMW with special attention to quality and performance while maintaining a reasonable price. Our intercoolers allow for higher HP gains, mainly due to their ability to keep intake temps down while preventing heat soak which is a common problem with the factory intercooler. This results in a more power and increased reliability with reduced chances of pre-detonation & knock. Intercooler Core The most important component of any intercooler is the core. The core cools the charged air from the turbo before it enters the engine and the OEM BMW tube and fin intercooler is designed to support low boost levels and air flow. Once boost levels and air flow are increased, the OEM unit is easily overwhelmed and can not keep up with the cooling demands of a tune running more than OEM boost levels. This results in heatsoak which will result in a power loss and a higher potential for pre-detonation in the upper RPM range. We remedy this problem with our custom bar and plate core design which utilizes a staggered and offset high density internal and external fin pack. Our core has been carefully tuned to provide the the best intake temperature reduction while maintaining minimal pressure drop. Our bar & plate core is also much more durable than the OEM tube and fin core, with a better ability to withstand rocks and other debris. Finish & Construction Our VRSF intercooler features 3D CAD designed cast aluminum end tanks for improved flow in comparison to sheet metal end tanks. Our CNC'd, one peice seamless cast end tanks are also more durable than comparable sheet metal or multiple peice end tanks. Every VRSF intercooler is finished in a uniform, bright silver coating which helps protect the intercooler from corrosion and ensures your VRSF intercooler holds up to the elements, no matter where you live. Every VRSF product includes our lifetime warranty & our "No Hassle" satisfaction guarantee which includes fitment & defects. Installation This is a complete plug and play bolt in option and we include everything required to repalce the OEM intercooler.All VRSF intercoolers feature tabs that allow the retention of the factory fan shroud. Our bolt on end tanks utilize the OEM intercooler piping. Each VRSF intercooler is hand finished and pressure tested to ensure a high quality, leak free experience. Our intercoolers fit both Left Hand Drive (LHD) & Right Hand Drive (RHD) Models as well as all XI models. Features High Desnity Bar & Plate Core Cast Aluminum Plug and Play End Tanks 87% larger than the OEM intercooler Easy install, less than 1.5 hours Includes lifetime warranty Dimensions: 21" x 8.5" x 5" Fits the following BMWs 2012-2016 F30/F31/F36 BMW 320i & 320xi / 328i & 328xi / 335i & 335xi (Also Fits 316i, 316d, 318d, 320d, 325d, 330d, 335d) 2012-2016 F32 BMW 428i & 428xi / 435i & 435xi (Also Fits 420i, 420d, 425d, 430d, 435d) 2014-2016 F22/F23 BMW 228i & 228xi / M235i & M235xi (Also Fits 220i, 218d, 220d, 225d) 2012-2016 F20/F21 BMW 114i / 116i / 118i / 125i / M135i / 114d / 116d / 118d / 120d / 125d
11-13-2015, 06:07 PM | #2 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
Fits on M sport bumpers without modification?
11-13-2015, 07:20 PM | #3 |
24206
Rep 190,807
11-13-2015, 07:28 PM | #5 |
24206
Rep 190,807
11-13-2015, 08:36 PM | #6 |
Rep 396
Nice! Def interested in this. Have a VRSF dp I bought from you and the quality is great on that. Wouldn't doubt that with this IC. I'm assuming this IC would work with an ER CP as well?
11-13-2015, 08:36 PM | #7 |
24206
Rep 190,807
yes it works with the ER charge pipe
11-14-2015, 05:11 AM | #11 |
24206
Rep 190,807
11-14-2015, 07:14 AM | #12 |
Rep 396
Price for me as well please
11-14-2015, 08:47 AM | #13 |
Rep 72
Mike,
This looks great! Got the VRSF dp from you and love it. Are they working on a charge pipe for F30? Would like to see a fmic / cp combo deal from them.
Mike
2018 M3 ZCP 6 MT |
11-14-2015, 12:40 PM | #15 |
24206
Rep 190,807
Done
11-15-2015, 04:26 PM | #18 |
24206
Rep 190,807
No same intercooler fits both
11-16-2015, 10:24 AM | #19 |
Rep 167
