      07-07-2014, 03:45 PM   #1
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Send a message via AIM to Ryan@IND
RKP M6 Front Lip DIY
RKP continues a tradition of flawless fit, incredible surface finish, and the most carefully plotted designs in the industry with their M6 front lip.
This install can be performed without a lift, but we utilize one to give a better perspective on the install.
Tools:
  • 8mm socket
  • Small extension recommend
  • appropriate sized ratchet for the socket (1/4", 3/8', 1/2" etc)
  • Tape (painters tape or scotch tape)
  • 3M adhesion promoter (Provided by RKP)
Step 1:
Make sure your work area is secure. If you are using jack stands please exercise caution and follow proper operating procedure. Using the 8mm socket, remove the middle screws on the factory lower lip.
Step 2:
At this point in time it is a great idea to test fit the front lip. This is standard procedure for all exterior parts that arrive at our facility.
Step 3:
Now that fitment is confirm please prepare lip for install by creating pull points for the double-sided tape. For this procedure we use painters tape, but any sticky tape can be used. The idea is to create a pull for when the lip is in the final stage of install.
Step 4:
With the factory lower lip loosened ensure there is a clean mounting surface. Now wipe the mounting surface with the provided 3M adhesion promoter
Step 5:
Install the front lip between the urethane lip (bottom) and the underside of the front bumper. Use the mounting holes as a guide for position.
Step 6:
Tighten the bolts half way into the front lip to ensure the lip is secured in place.
Step 7:
Using the tape pulls remove the double-sided tape from the lip and push the lip against the bumper with even pressure.
Step 8:
Fully tighten the bolts on the underside of the urethane front lip.
866-963-4520 FACEBOOK INSTAGRAM FLICKR
      07-07-2014, 04:20 PM   #2
RW Carbon
RW Carbon's Avatar
Drives: BMW F80 M3 & F87 M2
Nice write-up. Love the look of this lip on the M6
      07-07-2014, 10:02 PM   #3
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Now that is what I call instructions!
Brian
      07-07-2014, 11:32 PM   #4
///M 4 Life
///M 4 Life's Avatar
19
Drives: 2014 ///M6 CP
What are those little sensors on the front bumper in the lower grill area?
      07-08-2014, 12:45 AM   #5
MattUK
Captain Unsensible
MattUK's Avatar
68
Drives: 2016 M240i Coupe - Estoril
2016 BMW M240i  [0.00]
What would be really useful when posting pictures of new low key mods like this is a final picture comparing the original stock with the new.. someone like me who isn't quite used to the looks of the small parts yet could do with seeing them side by side..
Just an idea would be helpful
      07-08-2014, 07:11 AM   #6
Twitch Massacre
Twitch Massacre's Avatar
Drives: 2015 BMW i8
I12 BMW i8  [0.00]
F13 BMW M6  [0.00]
Laser shifters.
H&R Springs
21" ADV.1 ADVNL2 MV2 CS Wheels
Coming Soon:
2016 BMW M4 GTS De-Winged and Bagged on 22s
Copyright ©2000 - 2019, vBulletin Solutions Inc.
