08-12-2020, 02:21 AM | #1 |
Rep 13
tire recommendations
Hey guys i want to know about this setup
i am on stock wheels [ 2013 m6 GC ] and i can get the following combination. 275/35/20 front - Michelin pilot super sport 305/30/20 back - Michelin pilot sport cup2 OR 305/30/20 back - Michelin pilot super k3 my uses will be mostly on the road [ quite a rough road where i live all around ] i need traction to beat some wannabe's off a traffic light [ cmon we have an M6! ] and maybe a track day once in a blue moon. i dont care about tire noise, just need traction off the line mostly and a little bit comfort [ will not kill me if its rough i dont mind] thanks for the help guys! P.S i also thought about the Michelin sport 4s but i will need to order them and it will take about a month to get here. the tires above are available now. |
08-12-2020, 06:24 AM | #3 |
Rep 125
I run 275/35/20 and 305/30/20 Sport 4S on factory rims. I only have about 500 miles on this new set (32k miles on original tires). Haven't really pushed them to the limit yet, but there is really good rear traction with the 305s, considering all of the torque demand on 2 wheels. I would seriously consider waiting the month to get them. I'm not sure how I feel about mixing tire types front/rear.
08-12-2020, 04:38 PM | #4 | |
Fueled by Recycled Dinosaurs!
630
Rep 1,170
Drives: F06 M6
08-12-2020, 04:49 PM | #5 | |
Rep 390
Drives: 2021 G30 M550i
08-12-2020, 06:18 PM | #6 |
Rep 125
I agree with MelborneFinn, except I would go 275 front if you are going 305 rear. Staying 265 will create a slight understeer situation and the rolling diameters are closer between front and back if you go 275 and 305 (265 fronts will be too short).
08-12-2020, 10:10 PM | #7 |
Rep 13
Guys thank you so much for the advice. i think it is agreed among everyone to take the ps4s. sadly will have to wait for about a month but after doing research and hearing your advice it'll be worth it.
thanks again. |
08-12-2020, 10:23 PM | #8 |
Rep 13
Hi Guys, I have just read this thread. - https://f10.m5post.com/forums/showthread.php?t=1390088 -
Some people say you need spacers and some dont, anyone here that has been running ps4s 305 rear for a relevantly long time and could say that there is no rubbing? Also, In case there is a need for spacers, will the OEM bolts do? Last edited by lior; 08-12-2020 at 10:30 PM.. |
08-12-2020, 11:03 PM | #9 | |
Rep 242
08-13-2020, 07:43 AM | #10 | |
Rep 125
08-13-2020, 10:39 AM | #11 |
Rep 184
I just put on the PS 4S on all 4 stock wheels. 275 front 305 rear. There is no rubbing and god coming from P-Zero's these are amazing.
Stage 2 tune, dp and intake and in the summer I'm gripping. |
08-13-2020, 03:34 PM | #12 |
kr0m3assass1n
1094
Rep 861
Drives: 22 X7 M50i
Sorry guys, I'm new to an M6 myself and also in the market for new tires. I have the OEM 20" wheels.
My door panel reads: Front 265/35 ZR 20 Rear 295/30 ZR 20 I'm reading this thread and it seems I can go 275/35 ZR20 for Fronts and 305/30 ZR20 for Rears without any issues? Sorry if this is a dumb question but doesn't the aspect ratio also need to change if the tire width changes to maintain "equilibrium"? |
08-13-2020, 04:06 PM | #13 |
Rep 125
Those are the sizes you want. They get the rolling diameters as close as you can get them, in tire sizes that are readily available, and fit.
08-13-2020, 04:14 PM | #14 | |
kr0m3assass1n
1094
Rep 861
Drives: 22 X7 M50i
08-13-2020, 06:11 PM | #16 | |
Rep 117
08-13-2020, 06:25 PM | #17 | |
Rep 125
contact patch area is an X(Y) problem, a few mm of width does actually make a difference. You can put +10 tires on factory rims, no spacers, no rubbing, no changing suspension geometries. I would bet that there is a larger difference in the gain from tire width than the loss from tire weight. Also, wider section width gives you more rubber overhang and less likely to curb rash the rim, assuming you are into that kind of thing too. |
08-13-2020, 10:26 PM | #18 |
Rep 13
305 rear 275 front's ps4s ordered, thank you so much guys!
Was wondering something, Could a linear power delivery when accelerating have something to do with the tires? i just recently bought the car and the tires it came with are some cheap crap Chinese with 0 traction [literately]. When i accelerate hard [no matter from what speed] you get this uneven and not smooth power delivery its like the engine is tuning itself down on purpose [ and no its not traction control ] i did coils \ plugs last week issue still there. some guy in the m5 forum said it could be maf\o2 sensor i will try that out but i was wondering if the tires could have anything to do with it? |
08-13-2020, 11:22 PM | #19 | |
Rep 117
08-14-2020, 01:39 AM | #20 | |
Rep 125
08-14-2020, 02:23 AM | #21 |
Rep 13
traction control fully on [ still affraid to turn it off\partially off due to these tires i have now] car is in the sportiest settings besides the traction. but i do not see any intervention in the dashboard that the traction control kicks in.
you think it has something to do with it? |
08-14-2020, 03:00 AM | #22 | |
Rep 390
