      03-30-2020, 07:57 PM   #155
Qsilver7
Qsilver7's Avatar
Originally Posted by jackliu0527 View Post
how to load the map if i have CIC?
Originally Posted by burkhacs View Post
Looking for same answer
2013 650i GC
First, you need to verify the correct map version your car requires...and you can do that by going into iDrive to see what version of the nav maps you have. It will probably be the PREMIUM maps (not the NBT/NEXT/or NBT EVO). Once you get the correct map files and a FSC code then you upload them the same way as mentioned in this thread using the USB thumb drive in the data USB port. If you don’t know where this is...then refer back to your owners manual...it will give the location of the data USB port vs one that is for music sharing.
Pic below shows the screen for the map version in iDrive for a car that has the CIC and Premium maps:
      04-05-2020, 10:21 AM   #156
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Links to 2 separate shares are in the 1st post. Download both of them.
      04-05-2020, 12:24 PM   #157
ep3
Drives: 07 335i and 14 M6
Not having much luck. It's prompting for loads of individual zip file with folders mixed and split up. Some zip files were missing as well. I tried to go in and manually download the files but still no luck. It would split files from the same folders into different duplicate folders.
      04-05-2020, 03:41 PM   #158
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Google drive is messing with the way I original had it uploaded. I'll upload 2 ZIP files instead. Takes forever though
What browser were you using? I tested the single file downloads & those were normal. I use the new Microsoft Edge with Chromium
      04-05-2020, 07:38 PM   #159
ep3
You're good and much appreciated. Wasn't sure if it was just me. I found a torrent that works well. Okay to post it? Didn't want to step on your toes.
      04-06-2020, 07:25 AM   #160
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Go for it. The more sources people can use to get the map the better.
      04-06-2020, 08:53 AM   #161
ep3
Appreciated. Attached is the file in zip format. Unzip for torrent file.
File Type: zip BMW Road Map North America NEXT 2020-2.zip (292.9 KB, 877 views)
      04-11-2020, 11:42 AM   #162
warpeacelove
Drives: 550i
Where do i get the FSC code generator?
      04-16-2020, 09:55 AM   #163
ep3
It's all listed in the first post. It's up to you on how you want to do it. Some prefer to just buy the code and not deal with installing software, etc.
With that said, I purchased my lifetime code for like $15. I won't plug the site so I don't violate any rules, but there are several options for that. The hardest part was entering it into the iDrive with the scroll wheel.
      04-17-2020, 09:15 PM   #164
TomM6
TomM6's Avatar
Drives: F12 M6 individual
Do you have the link for the 2020-2 premium map?
      04-19-2020, 10:10 AM   #165
mlavio829
Drives: 2020 BMW 330i X Drive
Hi, When I try this, using the info the structure of the USB drive provided before - I get an error saying: please connect the USB device 1 to start the update.
Any ideas?
Thanks
Michael
      04-19-2020, 08:28 PM   #166
yewlock
yewlock's Avatar
Drives: X5
Free software to format large capacity USB drives to FAT32 >>>: http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
Use this free software to format drives to FAT32.
Any ideas?
Thanks
Michael
      04-23-2020, 02:36 PM   #167
bmwgvsc
Drives: BMW M4
Hello all.. I've been all over the place and trying to get some clarification.. I'm attempting to update my nav map files.. I believe I have all the software but obviously need this FSC code.. In the instructions on the first page it is saying you need to launch E-SYS launcher, however in all the reading I have, the existing E-SYS Launcher Pro EST file expired but I'm reading other posts where this is not needed to generate a FSC file.. Does anyone have instructions or can clarify if I can generate a FSC file without needed an updated EST file for the launcher?
Thank you!
      04-23-2020, 02:39 PM   #168
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by bmwgvsc View Post
...if I can generate a FSC file without needed an updated EST file for the launcher?
Thank you!
Yes, you can. Launcher not needed.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
BadSeed158.00
      04-28-2020, 11:00 AM   #169
bobster2020
Drives: F13, F20
Unhappy same issue as michael can someone advise
Any ideas?
Thanks
Michael
ERROR onscreen - please connect the USB device 1 to start the update
I have 100% formatted as fat32 on 32GB stick, I have NBT and next maps 2020-2. 640d 2014
thanks
      05-04-2020, 07:41 AM   #170
bobster2020
Drives: F13, F20
thanks
woohoo I fixed it.
      05-04-2020, 03:48 PM   #171
Flying Ace
Flying Ace's Avatar
4985
If you don't have enet, what's everyone doing to generate a FCS code?
      05-04-2020, 06:59 PM   #172
ep3
I used a company to generate mine because my car laptop is a pile of crap. It was like $15 for a lifetime code iirc.
Flying Ace4984.50
      05-14-2020, 08:51 PM   #173
AZ535i
AZ535i's Avatar
Drives: F10 535i
2013 BMW 535i  [0.00]
Thank you, BadSeed for this extremely helpful and detailed update! Couldn't of done this without your instructions.
BadSeed158.00
      06-10-2020, 11:14 AM   #174
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
A couple installation notes, trouble shooting, etc. this was done on an F15
For E-sys you don’t need it to be activated with a token, that’s only used for coding, to generate the FCS file I just used E-sys, NOT E-sys Launcher like the first post says, this worked for me.
You must use the provide software to format the drive as FAT32, exFAT32 does not work.
I tried to move the zip file in to the FAT32 formatted 128gb stick and had an error ‘file too large’ So had to unzip the files first and then move them over.
During the update the car would go into sleep mode and the update would stop, so I ran the engine for 45min-1hr for the update to complete,
I suspect you can drive around while its updating, but you just can’t use the navi
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
BadSeed158.00
      06-13-2020, 07:24 PM   #175
F31MGUY
Drives: BMW F31 M
Hey first I thank you for all the hard work and the input it's really great. So I have followed all the steps and went through the discussions before I post this. But i'm sure I have misunderstood or missed something please help.
-Using a MAC I have downloaded both zip files part 1 and 2 with safari web browser, from there I unzipped them before adding to the formatted FAT32 USB 3.0 key.
-Cleared folders like mentioned and had exact same folders as in the picture
-Plugged USB KEY in my F31 while engine running and nothing pups up, also tried in navigation mode still nothing.
I tried several times and hopeless LOL.
      06-13-2020, 07:47 PM   #176
rogerdiaz
Drives: 2015 335i
Thank you. Downloaded via torrent. Installed flawlessly on 2015 335i.
BadSeed158.00
