11-11-2020, 08:27 PM | #111 | |
Rep 313
11-12-2020, 06:12 AM | #112 |
Rep 3,071
"That sucks ..how about trying to update the software?"
I am running the latest software.
11-14-2020, 09:57 PM | #113 |
Rep 13
Had nothing but problems with my unit. The two (2) green fiber cables/connections do not work when moved over to the new harness. I suspect the harness is not OEM spec. Recall, you need to manually move those cables to the new harness. When I test the system, I get an error that the emergency call feature has malfunctioned (in the dash) and the SOS light (green) constantly blinks on/off. The BMW SOS/Emergency call system uses these cables (along with other systems) to communicate. As soon as I move back to the old harness (factory) the error goes away. Anyone experience anything similar?
11-14-2020, 10:09 PM | #114 | |
Rep 1,827
11-14-2020, 10:11 PM | #115 |
Rep 1,827
Quick update. I’ve switched from Android to iPhone and the Wireless Carplay on this unit is 100x better than the wireless android auto. It just works. With wireless AA the system would slow down to a crawl after maybe 30 minutes of use, requiring a complete reset. No such issues with Carplay.
11-15-2020, 04:47 PM | #116 |
Rep 3,071
I may sell mine and go back to iDrive. Maybe someone with an iPhone. I paid $300 a month ago....
11-15-2020, 05:08 PM | #117 |
Rep 407
Just FYI, wired (non-wireless) CarPlay unit is working for me flawlessly for over a year now. I briefly had an "upgraded" (wireless) unit and it was a mess.
11-16-2020, 07:19 AM | #118 |
Rep 3,071
When mine works it works wirelessly well, just to many issues, slow to connect, waze won't work and phone calls result in feedback loop at the other end. It will then work fine for awhile then have issues again. Arrgh
11-16-2020, 07:57 AM | #119 |
Rep 188
I must be lucky, for my iPhone this works flawlessly. I also just upgraded to the 12 pro with no change in operation. Once the module is connected to the phone the phone remembers which Bluetooth output to use for audio and then for the phone, I use both. I do not use CarPlay for the phone I have the phone Bluetooth set for the iDrive which eliminates the feedback loop issue.
Also there’s been a few people that have said that you can use the steering control wheel for control of the the CarPlay module, I have found that not to be the case. Mine still operates the phone through Bluetooth only when it’s connected separately to the iDrive, any attempt to use the control wheel on the steering wheel for audio etc. on CarPlay shows no function because of auxiliary input. I did try to connect to my daughters android, and I found it to not nearly be as functional as it is with the iPhone. But in fairness we have found that same issue in our Range rover which has a factory-based CarPlay system which also accepts android, i truly believe this has more to do with android than the module. |
11-16-2020, 10:21 AM | #120 |
Rep 242
Finally got to upgrading my unit to custom 2.0. Worked perfectly with a crappy old 512mb usb stick( sample garbage from a trade show). i tried with an 8gb and 16gb data traveler with no luck. Copied the file over to this relic and it worked perfectly. I am enjoying the experience so far. I'll check out Carplay as well but worried about having a locked EQ on my music. I know this has a built in eq but I dont want to have to touch that as it introduces another layer of potential quality loss and distrotion.
11-16-2020, 07:00 PM | #121 | |
Rep 313
11-16-2020, 07:04 PM | #122 | |
Rep 313
11-17-2020, 09:41 AM | #123 |
Rep 242
I never had an issue with downloading the zip files. My issue is when I selected the software update option and entered my PIN to start the update, it would kick me back out to iDrive (which it is supposed to do) but then when I went back in to see the update status, it never updated....just rebooted the unit. I transferred the same file from my desktop to a lower capacity USB stick and it worked.
See if you can find a USB stick that is 2GB or smaller in size. Dont forget to format it first in Fat32. |
11-18-2020, 02:09 PM | #124 | |
Rep 48
I don't know if this matters but I also turned off the factory Bluetooth. |
11-18-2020, 09:32 PM | #125 | |
Rep 313
11-18-2020, 09:34 PM | #126 |
Rep 313
Now just having small issues with autolink app ..after i deleted to clean all the BT connections the app doesn't want to connect .. haven't played with it to much ..ill try again tomorrow and see if I can get it to work .but besides that ..love this mmi unit ..works like a charm
11-18-2020, 10:17 PM | #127 |
Rep 48
Glad to hear you got it working. I was having issues with the autolink app before the update. I haven't had a chance to fully try it out. I installed the unit yesterday and updated this morning.
I setup Android Auto to automatically launch when connects the Carlinkit via Bluetooth. I noticed it would first connect via Bluetooth then when Android Auto launches it disconnects the Bluetooth seconds after and connects via WIFI. Only annoying part is when I go in the garage it would start the Android Auto even if the car is not on. That tells me the Carlinkit is always running. Btw, when I first connected after the update it would go through an Android Auto setup which sets up the WIFI automatically. |
11-19-2020, 11:31 PM | #128 |
Rep 313
I wonder if there's a alternative to autolink? Still not working since deleted and reinstalled it .. wasn't working that great to start with .rarely played sound thru the cars speakers...now it just doesn't pair ..
11-20-2020, 12:20 AM | #129 | |
Rep 48
See if you can reset android unit to the default settings and remove unpair/forget bluetooth and wireless. |
11-20-2020, 08:45 AM | #130 |
Rep 313
I think I got it figured out .. looks like , atleast in my case ..if I want to mirror my phone using auto link ..i have to connect the wire as soon as I get prompted to do so ..if I have it connected before I hit the mirroring then the autolink won't open and mirror my phone
11-20-2020, 10:22 AM | #131 |
Rep 286
I never got it working so just forgot about it. I will give this method a go.
Btw side note my android auto doesn't auto load I always have to gold menu down for 3 seconds then select the android pop up for wireless connection. Probably a setting wish i knew which one. |
11-20-2020, 12:29 PM | #132 |
Rep 242
How did you do this? Did you just unplug the battery for a while? My HUD is gone as well. Did not notice as i have been using AA this whole time. Went back to idrive to compare audio quality against my ipod and saw it is not working.
