      05-17-2020, 10:39 PM   #1
Whipple
Whipple's Avatar
263
Carbon Ceramic brake questions
Hey guys , I went to an Indy shop to have my tranny fluid changed , and he back to me saying my brakes are dangerously low , he said he plugged in his laptop and said Front brakes at 36% and rears at 12% . He said I have about another month and I don’t want to gouge the Ceramic rotors to change the pads
So I said to him did you physically check the pads? did you measure the thickness of the pads ? He said no but he test drove it and felt good no shaking , lmao
I like this shop but I felt insulted by him telling me this , I’m going to call him and confront him about. These pads with all the parts and Pads,springs,sensors and misc It’s about 1K in parts
Do any of you guys now how the dealer checks the pads?
Is it depending on thickness they recode mileage into the computer?
Is there a chart for mileage input according to thickness?
My pads are at least 1/4 thick yet Physically looking at them the outboards are at least ,I have to pull a wheel to check inboards
Anybody with experience with this and Carbon Ceramic brakes I’m all ears please chime in , Thank you
      05-18-2020, 02:01 AM   #2
brad850csi
Drives: 16 F13 M6 Comp
Pads are measured by their thickness. As they provide a heatsink to the discs you don't want to get them too low as that will accelerate the wear of the discs.
The discs are measured by weight, not thickness. Each disc will have a minimum weight printed on it.
      05-18-2020, 08:15 AM   #3
Badboy8813
Badboy8813's Avatar
46
Drives: F06 Frozen SS 2014 M6 CP
How much was your tranny fluid change service?
'14 F10 CP M5 AW/Full Sakhir Orange, Gloss Black 343Ms, Black IND Cosmetic Package, M Performance CF Diffuser and Spoiler. - SOLD
      05-18-2020, 11:31 AM   #4
Flying Ace
Flying Ace's Avatar
4985
To expand on Brad's comment here....
Pads are just one wear item and the computer indicator from the brake pad sensor is an estimate. A very good estimate based on my decades of BMW ownership, but still an estimate.
Your brakes likely will need changing based on those indicators.
To answer your question, dealers check the computer, and they perform a pad thickness measurement.
Now rotors is a whole different story. CCB rotors need to be weighed. You should not balk at the cost associated with dismounting each rotor to weigh them, but considering a whole set is $10,000, it's little money spent to gauge how much more life you have left. CCB's have relatively huge variability in manufactured weight, which means each rotor begins in life with a different weight. Also the precision involved in measuring the weight is very minute. So each one technically should be cleaned before weighing.
There is a visual indicator for rough estimate on the rotors. They are little dime sized circles etched into the rotor. When those circles become non-circles, that indicates the rotors wearing down towards the end of life.
The only way that I'm aware of that that you can measure rotor weight without taking the rotor off is with the carboteq tool.
https://www.proceq.com/product/carbo...c-brake-discs/
Most independent Porsche shops should have these laying around. You should take your car to these shops and pay them for a half hour of their time for using their tool. If you feel like your trajectory of ownership will be owning CCB equipped cars, you can probably just buy the tool out right. Pretty much all modern day exotics, and many mid tier Porsche models come with CCBs. Save you a lot of money over time.
Google BMW CCB rotor wear indicator and you'll see a BMW manual out there that shows you what to look for on the rotor. It's also in the video I posted above. There's still a minimum rotor thickness measure, but it's a high precision measurement, that requires calibrated tools.
Lastly there's a theory out there among CCB owners across all manufacturers that you should change your pads halfway through their life anyways. It somehow extends the longevity of your rotors. Don't ask me why, I haven't had time to pour through the forums discussing this topic and rationale.
MMMM6GC275.00
Whipple262.50
Havy303.00
ind_can98.00
yusko24.00
      05-18-2020, 07:56 PM   #5
Whipple
Whipple's Avatar
263
Hi they charged me $246 for parts=9liters of Motul DCT-F, upper and lower filters and $250 for labor they used ISTA to do the job it suppose to open valves and let more fluid into the transmission its a little more time consuming but im not sure 100 percent necessary
      05-18-2020, 08:21 PM   #6
Whipple
Whipple's Avatar
263
Thanks guys for the help,But I thought the wear indicator was incase you get to low it rubs through the sensor and breaks a connection and you get a brake warning on the dash ,that sensor needs to be replaced,
I didn't know the sensor can actually determine the actual thickness of the pad and determine mileage ??
I thought the way they check at the dealer is they measure the thickness of the pads and whatever that thickness is determines the mileage they code into the service onboard computer until next brake service is due ,I believe I can do this with the Carly app, just like I do oil ,and brake fluid service
      05-19-2020, 01:28 AM   #7
brad850csi
Lol thanks - a friend had just left after coming around to my place to celebrate NZ going back to being fairly open and I had quite a bit to drink, that was as many words as I could string together!
I'm now sober and did some searching Lemetier is amazing, check out his post in this thread specifically #63
https://f80.bimmerpost.com/forums/sh...1302752&page=3
      05-19-2020, 11:11 AM   #8
Flying Ace
Flying Ace's Avatar
4985
To clarify, you are correct. The wear indicator estimates the pad wear. The way it works is how you described.
The dealer checks brake pad thickness with a measurement. They only used the onboard computer as an indicator to look at things. After the pads and sensors are replaced, they reset the onboard computer.
      05-20-2020, 09:17 PM   #9
Whipple
Whipple's Avatar
263
Ok guys so I pulled all my wheels to check my pad conditions ,all pads are wearing evenly they all seem identical ,these are the original pads with 35k on them ,my fronts are still 1/2inch thick(12.7mm) from the pad backing plate to the rotor, and my rears are 3/8ths of an inch thick(9.525mm) ,the rears are closer to worn than the fronts.
All my Rotor wear indicators are still solid and round so im not to worried about the condition of the rotors.
You will see in the pics the distance between the pad wear sensor and the rotor ,I believe im still in a safe zone for some time.
I made the final decision upon the info you guys gave me and the cost of rotor replacement to just go ahead and change the pads,I think thats the smartest thing to do.
Im was also contemplating to do the job myself,but im gonna let my indy shop just take care of it as they do them all the time,I have done tons of steel brake setups before and I know its the same concept but I dont want to miss anything and gouge a rotor ,as they say penny wise dollar foolish
Let me know what you guys think of the pics ,would you change them yet?
Thanks again for the help!!!!
Flying Ace4984.50
      05-21-2020, 11:39 AM   #10
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
Remember the rotors last a life time (300000km) Under normal conditions (no tracking)
Whipple262.50
      05-21-2020, 12:21 PM   #11
Flying Ace
Flying Ace's Avatar
4985
Good call OP on changing the pads. Since you're taking it to a independent shop, you should give him a heads up regarding carbon ceramics in the context of ensuring that they have appropriate insurance in case they damage it. Most reputable shops has enough insurance.
      05-21-2020, 03:19 PM   #12
Whipple
Whipple's Avatar
263
Good point, That’s another reason why I don’t want to do it myself, in the beginning I thought the shop was trying to just gat a brake job out of it ,now what I know he was just helping me keep my rotors in great shape ,
I contacted him waiting on prices to do the job,I asked him if he uses OEM brake pads he said no he uses another brand that the guys love , but he said if I want OEM that’s fine he will get me prices for both , I’m actually Surprised there is a aftermarket pad for Carbon Ceramic discs , unless he was mistaken for steel rotors , I tried searching and found nothing
      05-21-2020, 03:23 PM   #13
Whipple
Whipple's Avatar
263
Yes , That’s what my shop actually told me , I read the brochure on CCB and anything over 600 degrees can accelerate rotor wear , I’m just using on the street , I watched the temp the other day normal driving with some hard stops they barely hit 100 degrees lol
      05-21-2020, 04:39 PM   #14
Flying Ace
Flying Ace's Avatar
4985
I highly recommend sticking to OEM/Brembo pads.
      05-21-2020, 09:40 PM   #15
Whipple
Whipple's Avatar
263
LOL,How did I know you were gonna say that,I think I just wanted to hear you actually say it
      05-21-2020, 10:45 PM   #16
Flying Ace
Flying Ace's Avatar
4985
How many miles are on your car?
      05-21-2020, 11:35 PM   #17
Whipple
Whipple's Avatar
263
35k
      05-27-2020, 10:08 PM   #18
Whipple
Whipple's Avatar
263
Ok so we were right, they dont make aftermarket brake pads for the Carbon Ceramic brakes only the factory Brembo pads are available,So I got the estimate,Its roughly $975-$1050 for all parts needed I shopped around for the parts and Labor is 400 bucks so looking at around $1500 for the complete job,Like Flying ace said use the factory Brembo pads I am more comfortable with stock pads anyway especially on the CCBs
It does seem like a lot of money for pads but if your saving your $12000 rotors it kind of makes sense LOL
      05-28-2020, 08:10 PM   #19
Whipple
Whipple's Avatar
263
Do any of you guys know the gold touch up paint color for the caliper? as you can see in one of my pics the front caliper looks like it got gouged from a wheel weight someone put it in the wrong spot
      05-29-2020, 04:06 AM   #20
Airz
Drives: 2015 M6 Sakhir Coupe
I have to say that reading this thread makes me think CCBs are more trouble than they're worth unless you plan on doing a lot of fast track driving.
The standard brakes are pretty good and upgraded fluid and pads would be enough for most people for the odd track day.
      05-29-2020, 05:46 PM   #21
brad850csi
Fast road driving yes, but not track driving as you'll overheat them and destroy them very quickly.
      05-29-2020, 05:46 PM   #22
Flying Ace
Flying Ace's Avatar
4985
You have it backwards. CCBs wear significantly faster for track cars. So using CCBs for performance driving will break your wallet.
CCBs makes most sense for street cars, heavy street cars. Over the course of 7-8 years, it may be cheaper to own CCBs than steel brakes on such a car and driving environment. Over 7-8 years, you would have spent $9-$10k on steel replacements, about breakeven for the CCBs over the same mileage. (Assuming 10k miles a year)
