      01-03-2019, 10:23 PM   #1
Xx__xs
Drives: m6
solved
So I removed both charcoal air filters, on the right side I had to disconnect the MAF sensor so I can get to the 7th screw, I reconnected when done. I checked my codes and am getting the following error code
I erase the code and it comes up immediately when I recheck it.
I did not find a single instance of this code anywhere on the internet. Temperature sensor interrupted? Does this have anything to do with the MAF sensor I unplugged?
I should say that the car runs normally, no CEL or anything else. Runs just like it did before.
      01-04-2019, 04:15 AM   #2
Havy
V8 addicted
Havy's Avatar
Germany
76
Drives: M6 Gran Coupé
It says error in contact NTC steering wheel_LIN temperatursensor interrupted.
      01-04-2019, 05:59 AM   #3
Xx__xs
Drives: m6
what does that mean?
      01-04-2019, 08:05 AM   #4
Havy
V8 addicted
Havy's Avatar
Germany
76
What the NTC or LIN means I don’t know. The frase means the the contact of the temperature sensor of the steering wheel heater is corrupted. Do you have the BMW Code?
      01-04-2019, 07:16 PM   #5
Xx__xs
Drives: m6
ahh, thank you i figured it out. i got a Dinmann CF wheel the other day and he disconnected my steering wheel heater plug so its that plug error code.
Havy75.50
      01-05-2019, 03:45 PM   #6
carl0s
Drives: 2004 545i & 2001 330i
NTC is a type of temperature sensor.
LIN is a data bus, like CAN bus, and is used for communications between various devices in the vehicle.
Havy75.50
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
