      11-23-2020, 03:28 AM   #23
aann
Drives: f13 M6 2016
Originally Posted by TinCanSailor View Post
Yeah, I'd change the coils and take a look at the gap and condition of the plugs while you are in there. Maybe even the o2 sensors or at a minimum the post cat sensors since the pre-cats are easy to reach.
Which one of these coils part numer fits the M6 2016 ??
12-13-8-647-689
Or
12-13-8-611-236
Im confused ??
      11-23-2020, 09:41 AM   #24
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
12-13-8-647-689
Or
12-13-8-611-236
Im confused ??
Do you know your production date?
      11-23-2020, 05:22 PM   #25
aann
Drives: f13 M6 2016
Yes , its 01/2016
      11-23-2020, 06:00 PM   #26
TinCanSailor
630
Drives: F06 M6
Yes , its 01/2016
I was looking on realoem.com and thought I'd find a conclusive part number based on build but it looks like either are valid. The coils are Genuine BMW part numbers the ones ending in 236 state for years 2016-2018, made by delphi, and the part ending in 689 are for 2002-2018, made by bosch.
Seems like either are valid but you could buy the Delphi or Bosch branded equivalents far cheaper and they are the OE providers.
      11-23-2020, 11:56 PM   #27
aann
Drives: f13 M6 2016
Both fits , its confusing!!!
      11-24-2020, 06:41 PM   #28
TinCanSailor
630
Drives: F06 M6
Exacly thats what i thought too , since both coils are valid for my car , i did not know which on is the best !!!
Visually different but functionally the same but one would think they'd have some guidance on them.
      11-28-2020, 04:06 PM   #29
aann
Drives: f13 M6 2016
After scanning the car i recieve charge pipe low pressure , i checked the charge pipes and the clamps but they looked fine to me with no leaks
      11-29-2020, 12:03 AM   #30
Spacecpe
Drives: E90 335i Msport
That's just the code the DME throw when you're in limp mode.. it's the result of other codes popping up.
      11-29-2020, 08:07 AM   #31
aann
Drives: f13 M6 2016
But there is no other codes ....
      12-11-2020, 06:58 AM   #32
aann
Drives: f13 M6 2016
The car stil behave the same , yesterday i had p0304 code which obviuosly
Missfire on cylinder number 4 .
      12-11-2020, 09:27 PM   #33
Spacecpe
If you replaced spark plugs and coil packs then your next on the list is injectors.
      12-13-2020, 12:43 AM   #34
Whipple
Whipple's Avatar
263
Yeah, I’m seeing on Instagram S63tu engine builders recommending to change fuel injectors @ 40k miles to help minimize engine failure
      12-13-2020, 07:50 AM   #35
mikerx5
mikerx5's Avatar
461
Drives: 2014 F06, 2022 G06
What is the recommended mileage for spark plugs and coil packs? Thank You
      12-14-2020, 12:16 AM   #36
Spacecpe
Id say every 20-30k stock and every 10k tuned. Yes don't play with injectors, i would replace them before they even show signs of failure if i were you. I have 40k kms on mine and changing them right away. If they leak, you will have misfire codes and they will dilute the oil and can cause a lot of issue (detonation/bend rods, rod bearings failures)
      12-14-2020, 03:35 AM   #37
aann
Drives: f13 M6 2016
Here is what i see on ista , misfire on cylinder 4 , but the p0299 fault code ( charge pressure low ) that i had at first is not exist .
The car still reduce power on accelaration .
      01-10-2021, 05:37 AM   #38
aann
Drives: f13 M6 2016
Cleared the all codes , but still the car is in limp mode , and wont accelerate .
      01-24-2021, 03:23 AM   #39
aann
Drives: f13 M6 2016
Okay , finaly we found the the problem : 🙄
      01-24-2021, 12:04 PM   #40
TinCanSailor
630
Drives: F06 M6
is that cotton packing material in there?
      01-25-2021, 09:09 AM   #41
aann
Drives: f13 M6 2016
Yes , we found a toilet paper in there that blocked the air 😐
The only explanation for that is that it maight be forgetten by the guy who changed my air filters .
      01-28-2021, 12:10 AM   #42
TinCanSailor
630
Drives: F06 M6
Jeez. I don't know if I would be livid or thankful. Glad to hear it was something simple though.
      02-07-2021, 05:39 AM   #43
aann
Drives: f13 M6 2016
Not that simple , but im glad that the problem solved 🙏
      02-08-2021, 12:52 AM   #44
jjasonSU
Drives: 650i, NSX
never seen anything like this
