09-27-2020, 03:24 AM | #1 |
Rep 1,817
F12 Ambient Lighting Upgrade - Using OEM Optics
A couple of weeks ago there was a post about ambient lighting updates available to the F12/F13/F06. Long story short, without significant wiring and software updates there is no way to get multi-colour ambient lighting in our cars. This got me thinking about what options we had other than sticking aftermarket LED strips over the existing optics.
I found THESE on amazon. The thing that stuck out was that you could use the existing optics with the new light units. This is the result: Obviously the photos from my phone are enhanced so I did some manual adjustments to more closely simulate what it looks like in real life, and this is the result: The result is not crazy bright or garish at all. I attached the supplied LED drivers to the factory optic strips. Running the connecting wires into the car was a wee bit of a challenge since there is no wire tunnel through the door harness. I overcame this by running them out the bottom of the door, under the rocker panel covers, illuminate sill plate and up into the car under the weather seal. Pretty clean, invisible install. I added footwell lighting front and back using the supplied fibre optic cables. The optics are hidden under the trim panels and the rear seat bench so they are not directly visible. Pretty happy with the result. Took a fair few hours to do but I did remove the seats to properly hide the fibre optic cables for the the footwell lighting. The cables are all routed to the armrest storage. The setup for the app used to change the colours was seamless and works as expected. Last edited by hugo_nz; 09-29-2020 at 12:26 PM.. |
09-28-2020, 06:16 PM | #2 | |
Rep 30
09-29-2020, 03:49 AM | #3 | |
Rep 1,817
I was not convinced about ambient lighting until we got the X5. It left me wanting more every time I got into the 6. You could, conceivably use different controllers to power the upper and lower LEDs to give you a two-tone look as well. |
09-29-2020, 10:16 AM | #4 | |
Rep 289
09-30-2020, 07:07 AM | #5 | |
Rep 15
09-30-2020, 08:40 PM | #6 |
Rep 1,817
10-04-2020, 09:39 PM | #7 |
Rep 15
Keysersoze81927.50 |
10-04-2020, 10:52 PM | #8 | |
Rep 1,817
10-31-2020, 05:14 AM | #9 |
Rep 86
“I attached the supplied LED drivers to the factory optic strips.“
“make some modifications to the original optics and door cards to fit the aftermarket light modules” What kind of modifications and how u manage connect to the original fiber? |
11-01-2020, 03:03 PM | #10 | |
Rep 1,817
The modifications include cutting away the tab that holds the existing LED emitter to the door card, and then cutting off the notch from the existing optics to allow them to slot into the new LED emitters supplied with the kit. The factory optics are exactly the same diameter as the ones supplied with the kit so they fit perfectly once the little notch is cut off. And yes, this can be reverted. The original wiring is left intact since it's not used in this retrofit. The factory LED emitters can be stuck down with some glue if you want to reinstall them. The factory optics can still slide into the factory LED emitter so no harm done there. |
04-18-2021, 02:37 AM | #12 |
Rep 1,817
Update (18/04/21):
I decided to take a 2nd stab at the ambient lighting upgrade I did a while back. The first iteration was good, but the location of the fiber light guide meant that the light was inconsistent in both light output and also from a visual appeal perspective from the driver seat. Today I moved the driver side light guide up a notch from below the carpet strip where it was originally to below the leather strip. The results look much better! I used an internet sourced image below to show the original (pink line) vs new placement (blue line) and then took some photos tonight to show the results on the driver side vs the current placement on the passenger side.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
LJohnson32212.50 |
04-19-2021, 12:49 PM | #13 |
Rep 14
This looks unbelievably good 👍
I HAVE to do this to my 2012 640. Been looking for something like this for a LONG time! So the plastic clear strip that's in the door now that lights with a very dim orangey red comes away? Replace whatever it is that's plugged into that with the drivers from the amazon thing and then plug the new light strip into that and run it in the space where the clear plastic strip was? Sorry for the basic questions! I'm actually an electrical engineer believe it or not 🤣 |
04-19-2021, 12:59 PM | #14 |
Rep 14
04-20-2021, 08:09 PM | #15 | |
Rep 1,817
04-20-2021, 08:11 PM | #16 | |
Rep 1,817
This is a new threadless kit. This means that you wire the power directly in the doors, and the light modules connect wirelessly to the master control. This removes the need to thread wires from the doors into the cabin (which is not an easy task). I will be replacing my setup with these too soon.
05-19-2021, 11:00 PM | #19 |
Rep 1,817
It's not out of the realm of what's possible tactually. Without being too technical, when you change the drive modes the car sends CAN signals to several components so technically it should be possible to create an intercept module that can take that information and communicate directly with the LED control box to change the LED colours.
05-22-2021, 07:44 PM | #20 | |
Rep 197
I hope its only a matter of time before someone goes ahead with it and figures it out If you know more I'd love to hear it - any direction would help.
But just imagine how cool and fitting it would be too - how on earth did BMW not do this. Why did they do what they did ?! Quote:
05-24-2021, 02:19 PM | #22 |
Rep 79
Just finished this up over the weekend, a bit more difficult in an f06 but worth the work. Not sure if anyone is going to attempt this but I would be happy to guide, I did use the threadless kit and definitely much easier. I also used wire taps so no cutting/splicing.
