01-11-2021, 05:28 PM | #199 | |
Rep 18,742
Or you can point to unique situations of low-rate production engines with over-stressed parts. Yay! |
01-12-2021, 02:03 AM | #200 | |
Rep 7,299
I certainly wouldn't rely on low / consistent lead levels and conclude you don't need to swap out your bearings at high mileage or something. Without a detailed analysis of their methods, it's just a guess. For example, factors that matter could include what kind/size of particulates the rod bearing wear produces and how it interacts with the filter media. |
01-12-2021, 06:29 AM | #201 | ||
Rep 10,358
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
01-12-2021, 07:16 AM | #202 | |
Rep 2,665
The warranty has zero to do with it. Thanks for all of the information.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
01-12-2021, 07:25 AM | #203 | |
Rep 2,665
See below. https://www.zpost.com/forums/showthread.php?t=1493760 [I]Lead – Usually a soft metal, most common related to bushings and Rod Bearings. Engine oil which are highly oxidized can attack the bearing material, leads to increased lead readings. Iron – Mostly comes from Cylinder liners, Rings, Crankshaft, Camshaft, Rods, Valve Train, Oil pump gear, Wrist pins, cast iron components and Gears. Usually found as fine particles due to abrasion or wear. Aluminium –Generally comes from Pistons, Turbo Bearings, Main and Rod Bearings, pumps, thrust bearings and washers, plates and Aluminium castings. Aluminium associated with silica indicates dirt. Aluminium found in hydraulic system should be generally due to dirt ingestion and in final drives can be associated with dirt or sand. Copper – Usually like a soft metal present in Main and Rod Bearings, Oil Cooler core, Clutch plates, Brass and Bronze bushings and Roller bearing outer cage. In engines it should be due to the water pump leak or coolant core. If it is found along with potassium, sodium and glycol, it will be coming from the oil cooler. If it is found along with lead and tin, it will be coming from bearing or bushing.[/I]
01-12-2021, 10:04 AM | #204 |
Rep 90
My life long experience, logic, reading and consultation with mechanics has guided me to change the oil in my cars in and around 5K miles. I change the oil not because of the reason that it breaks down rather because it is dirty. Tracking a car is a whole different situation when it comes to oil change philosophy and science. I followed the condition based maintenance schedule in my 330. Near the end of the warranty period the diagnostic sensors started to generate maintenance lights that were engine related issues. It’s been awhile since that time and I can’t remember exactly what those diagnostic codes were. However, I do remember carbon and oil sledge build up were found when troubleshooting the issue. Once I went back to the more frequent oil change schedule I never had those issues again with that car. Henceforth and like I did prior to the 330 I never had an engine related wear issue. Lastly, and to the point(s) mentioned by others the engine needs to be routinely exercised - it was designed and built to operate to its capacity. This is especially true in M like model cars. I try, when conditions exist, to max out the rpm’s in all the gears each time I drive the car. It’s a win-win situation if you know what I mean. ��
01-12-2021, 10:04 AM | #205 | |
Rep 18,742
So fine, if you buy a E46 M3, Z4M, or even a E9X M series you can use oil analysis to figure out when the rod bearings will bite the dust. But for 99.999% of owners, an oil analysis is not necessary, even if you are a BMW enthusiast and think it's cool to have your oil tested in your-over maintained BMW. Warranty does have to do with it, because track use is generally not covered and is considered excessive use that voids the factory warranty. So if you buy a new car and then track it, an oil analysis may tell you the engine is experiencing undue wear on internal, oil-lubricated parts. But the end result is the same, the manufacturer will not cover engine damage due to track use. Last edited by Efthreeoh; 01-12-2021 at 09:04 PM.. |
F32Fleet3587.00 |
12-21-2023, 06:12 PM | #206 |
Rep 77
I'm new to the n54 scene. Tryna figure out which oil is best to use, Castrol gtx or liqui moly molygen?
Here in the UK both are about the same price. 5L is around £40-42. |
12-22-2023, 02:38 AM | #207 | |
Rep 2,987
Drives: A Family Sedan
E93Dude369.00 |
12-22-2023, 06:29 AM | #208 | |
Rep 18,742
This warranty shall be null and void if the vehicle identification number has been altered or cannot be read, if the odometer has been replaced or altered and the true mileage cannot be determined, if the vehicle has been declared a total loss or sold for salvage purposes, or if the vehicle has been used in any competitive event.
12-22-2023, 07:52 AM | #209 | |
Rep 2,987
The warranty absolutely covers cars that break on track. Not if you’re in a competitive event, as stated. |
12-22-2023, 08:50 AM | #210 |
Rep 18,742
If you have evidence that you broke your BMW at the track then had it fixed under warranty stating to the SA that you were tracking your car at the time it broke, then post such proof.
12-22-2023, 08:51 AM | #211 | |
Rep 2,987
Plus, I mean, BMW organizes track events for us to attend as owners… imagine our cars breaking down and them saying “yeah you’re SOL, I built this event and invited you but you shouldn’t have come!” |
12-22-2023, 10:25 AM | #212 | |
Rep 18,742
Regarding BMW track days. My understanding is that BMW N.A. sponsored track days use BMW corporate cars rather than the owner's personal cars (that'd be an insurance nightmare for BMW). The language in the citation I provided is clear. Every warranty claim is adjudicated by the manufacturer on a case-by-case basis. But you are free to take your chances with your car. Last edited by Efthreeoh; 12-22-2023 at 11:43 AM.. |
12-22-2023, 10:30 AM | #213 | |
Rep 2,987
12-23-2023, 06:45 AM | #214 |
Rep 18,742
