      04-05-2021, 02:09 PM   #1
eagmail
Drives: 2014 M6
F06 m6 bc forged offsets
Found a deal for some
20x9
And 20x12
Front - 35
Rear - 45
These are offsets negative
Would this fit good on a f06 m6?
      04-05-2021, 02:46 PM   #2
brad850csi
Drives: 16 F13 M6 Comp
Front is too narrow and 4mm further in than stock. The rear is 26mm in too far compared to stock.
      04-05-2021, 03:28 PM   #3
HeyKC
Drives: BMW M6 CP
Compare here https://www.rimsntires.com/specspro.jsp
Stock are: 9.5 ET31 & 10.5 ET19
      04-05-2021, 03:39 PM   #4
eagmail
Drives: 2014 M6
Just checked it says that it fits fine ?
But don’t wanna take chances on some random thing does anybody know about this ? Found great deal on wheels
      04-05-2021, 03:40 PM   #5
eagmail
Drives: 2014 M6
I’m running 433 wheels have a 14 m6 competiton with carbon ceramics
Also run a 15” spacer in rear on 305/30/20 tires right on fender with spacer
      04-06-2021, 07:46 PM   #6
eagmail
Drives: 2014 M6
Anything ?
      04-06-2021, 09:22 PM   #7
jjgrizz73
jjgrizz73's Avatar
Drives: 2015 M6 GC
I have wheels from an m5 on mine BC forged, +20 offset fronts that fit perfect with no spacer and a +30 offset 21x11 with a 12mm spacer that puts the tire just inside the quarter panel.
You'd need spacers for sure.
      04-06-2021, 09:55 PM   #8
eagmail
Drives: 2014 M6
You wanna sell those grizz posted on your thread.
      04-06-2021, 09:57 PM   #9
eagmail
Drives: 2014 M6
The ones I’m looking at are a negative offset not +
      04-06-2021, 10:46 PM   #10
eagmail
Drives: 2014 M6
This is correct sizes
20x9
20x11
Front +35
Rear +45
      04-07-2021, 07:30 AM   #11
HeyKC
Drives: BMW M6 CP
20x9
20x11
Front +35
Rear +45
I'm not a huge fan of going narrower in the front but I think 265s will still fit. Offset basically the same.
On the rear you can probably pull it off with spacers but that looks like a better wheel combo for an M5.
Would not buy.
      04-07-2021, 08:30 AM   #12
eagmail
Drives: 2014 M6
265s fit fine. And actually pretty good on that wheel just seen it with that tire
I’m concerned about rear not clearing suspension ? I was thinking of a 20mm spacer ? Maybe 10-15 I do want my tire close to fender
I have stock 433wheeks at moment with a 15mm spacer and it sits perfect so I’ll probably do a 10mm on rear ?
I’m running 275s front right now and 305s rear no issues 15mm spacer rear 433 oem wheels
      04-07-2021, 12:03 PM   #13
HeyKC
Drives: BMW M6 CP
If you want to get the wheels then get them and keep us updated.
Yes there is a chance you will need a 20mm spacer just to clear your suspension. There is a chance you want to go bigger to get the tire fitment you want also.
      04-07-2021, 08:02 PM   #14
jjgrizz73
jjgrizz73's Avatar
Drives: 2015 M6 GC
They won't work if they are negative offsets btw
      04-07-2021, 08:44 PM   #15
eagmail
Drives: 2014 M6
They are positive
      05-05-2021, 12:19 AM   #16
jjonesfc
jjonesfc's Avatar
Drives: M6 GC
lowering
What did you use to lower it?
      05-06-2021, 10:23 AM   #17
jjgrizz73
jjgrizz73's Avatar
Drives: 2015 M6 GC
Nothing it's stock competition height
