12-24-2020, 08:56 PM | #1 |
Rep 304
It all started with a bimmerlink diagnosis based on the dreaded engine light that would continue to get triggered even after clearing the fault various times...
Thanks to help here and verifying the faulty oxygen sensor located on bank 2, upstream which is pre cat... Once I was able to order the deep socket wrenches and confirming for a second fine I went ahead and ordered the sensor... then i got right into it. I rigged up a straw vac to clear the sandy particles in the socket before removing the sensor... I then cleaned the socket area carefully to remove any obvious grime and dirt... the sensor itself seemed easy to install, thankfully it was the upstream and not the downstream which would have involved removing more hardware to make space to work that sensor... My Christmas gift was hopefully erasing this engine light for good lmao! And plus saving a shit ton of money having done it myself! I'm not sure what the dealer would have charged me but basically my our of pocket expense was the sensor which was about $250+ and the deep socket wrench which was like $10... all in all a win. Cheers! |
12-27-2020, 03:18 PM | #3 |
Rep 304
Maybe I spoke too soon! Engine light came back and the error is coming back as the same ...
Any ideas after replacing the oxygen censor on bank 2, upstream (pre cat)? Unless I replaced the wrong one?! US left hand drive - specifically replaced the driver side front most censor - assuming that's the correct one based on the error bimmerlink is reporting... Any help is appreciated |
12-30-2020, 03:15 PM | #4 | |
Rep 90
12-30-2020, 08:11 PM | #6 | ||
Rep 304
01-02-2021, 11:39 AM | #8 |
Rep 142
are you running catless downpipes? if so then yes those are the correct upstream sensors and the secondary sensors dont really matter. Id take a look at your MAF and clean those as well. Maybe even need to be replaced
01-02-2021, 06:53 PM | #9 |
Rep 304
70,859 miles
I took a nice road trip to key west and back yesterday and no engine light prior to having cleared it. I'm assuming that last engine light trigger was pre sensor replacement - and perhaps I did not notice as such. So I'm super happy after 200 miles of driving or so all good. She drives excellent. Probably better then when I got her at about 40k miles or so. I need to take pics professionally polished and posing to a nice backdrop but here is a snap of the dash mileage readout. |
01-02-2021, 06:54 PM | #10 |
Rep 304
01-03-2021, 11:05 AM | #11 | |
Rep 56
My car is at 70K miles too. I'm going to replace mine as well for preventative maintenance. Oxygen sensors last around 60k-90k miles. In case people look for this too. Bosch is the OEM for this part. RockAuto has the best price for it. BOSCH 16792 Actual OE Oxygen Sensor Info Downstream BOSCH 17187 Actual OE Oxygen Sensor Info Upstream |
01-15-2021, 09:01 PM | #12 |
Fueled by Recycled Dinosaurs!
630
Rep 1,170
Drives: F06 M6
I dig the vacuum straw setup and appreciate the diy.
04-16-2021, 02:42 AM | #13 |
Rep 304
Updating my progress after this was installed... my continued to get engine light error but with the down stream sensor this time... I ended up ordering a second sensor for the same bank 2 but this sensor was specific for the downstream as the error noted...
After I replaced it the engine light went away for a while along with permanent error I was getting... however recently the engine light came back on with a "mixture too lean"... I figured I needed to check the MAFs and get these cleaned with the proper cleaner which I did and so far so good... the permanent error is gone and so is the engine light now... Long story short I also as of today did spark plugs and coils myself - was fun! So far so good!! I'll post back if anything changes. |
09-13-2021, 04:28 PM | #14 | |
Rep 5
Just curious, how hard was it too install the rear oxygen sensor? Any photo like you had for the front? It seems like the running rich or lean problems can take some time to sort out. |
09-23-2021, 08:19 PM | #15 | ||
Rep 304
The oxygen censors have a very fragile plastic sleeve around its cable which can easily get coughs on the top bracket as you install the new censor so just take your time and care for the cable from getting dragged as you ratchet the censor into its socket… |
