      06-20-2021, 09:34 AM   #221
ron7165994
ron7165994's Avatar
Drives: BMW 750IX
Originally Posted by ponytuning View Post
Unable to download second file, when my connection drops mid-download or almost done it is unable to resume - happened 4 times already
same thing is happing to me too
      06-20-2021, 10:09 AM   #222
ron7165994
ron7165994's Avatar
Drives: BMW 750IX
[Image: 8eb6f583-c94a-4c8c-a447-1e4e446d39bb.jpg]
Content Unlocked:
https://drive.google.com/drive/folde...dYvIkbGk-rnnf_
https://mega.nz/#P!AgEEHRedutMY4_HQM5_lC...Kif-N1cAts
Decryption key is bimmerscene.com
Password to all uploads is bimmerscene.com
[Image: logo.png]
      07-01-2021, 06:58 PM   #223
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Links to 2 separate shares are in the 1st post. Download both of them.
64GB USB Flash drive required for this map update
>>> Generating FSC code for map updates - BMW_CIC_FSC_Generator.exe <<<
Note:As of 07-01-21, 2022-1 missing from the Maps drop down menu. 2022-1 info missing in Lookup.xml
Below is untested since I already have a lifetime code but you can try it out: Copy & paste to Lookup.xml file
<SgbmId id="NAVD_000014B8_255_005_194" SWID_FscShort="00A80059" name="Road Map NORTH AMERICA Next 2022-1" supplier="NTQ" sop="01.06.2021" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR="" NextNo="01475">
<EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" />
<SwUpdate SwUpdateEntry=""/>
</SgbmId>
      07-01-2021, 07:02 PM   #224
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Originally Posted by wt888 View Post
Through trial and error, I found a solution why many USB drives don't work despite FAT32 formatting.
Many drives are seen by the PC as "Local Drive" in "My computer", as if they were backup hard drives, not portable memory sticks. After inserting
the USB drive into your car and getting a message to update it, an error message then says to insert the USB drive, and you can't get past it. The solution is actually to use a USB drive that is recognized as "USB Drive" in "My computer". If it shows up as Local Drive, your car won't see it as a USB drive either. The solution is to get another USB drive. I believe it has something to do with windows compliance standards, whether your memory stick shows up as USB Drive or Local Drive.
Thanks for this. I will add to the 1st post
      07-09-2021, 06:38 PM   #225
ramman434
Drives: F30 335i
Hey guys,
I'm getting the USB error mentioned above when I plug into my car. However, you can see from my computer screen shot that it does show up as a "USB Drive", and not a hard drive. Any thoughts?
This is on a '16 535
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
      07-09-2021, 06:50 PM   #226
ramman434
Drives: F30 335i
So I think I figured out that the format was wrong on my drive. I just downloaded the free re-format program (link 2, #1 doesn't work).
However, all it looks like it did was wipe my USB. Doesn't look like FAT32 is an option
      07-09-2021, 08:20 PM   #227
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Free program on link 1 has been fixed. Didn't realize the webpage changed.
http://ridgecrop.co.uk/download/fat32format.zip
Personally I only use USB Flash drives.
This is what I use and it always works for loading maps https://www.amazon.com/Patriot-Super...tronics&sr=1-1
Your USB drive is 1 TB in size which to me is basically an internal drive in a USB enclosure. Not sure if it will work but you can try the application FAT32FORMAT & see if it makes a difference
      07-09-2021, 08:32 PM   #228
ramman434
Drives: F30 335i
Thanks for your help! I'm going to try it one more time on the 1TB flash drive. I'll report back if it finally works, but don't have high hopes.
I went ahead and ordered that 64GB drive that you use, and I'll have it Monday. Thanks for posting that link, as I was trying to search Amazon already for a FAT32 formatted flash drive that had a large enough capacity.
      07-09-2021, 08:38 PM   #229
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
No problem. SO when you used Rufus, instead of Large FAT32 it formatted your 1TB drive as exFAT? or when you used Rufus, you did not get the option to select Large FAT32
      07-09-2021, 09:15 PM   #230
ramman434
Drives: F30 335i
When I used Rufus it let me select "Large FAT32", and I had it at exactly like your screenshots. I let the program run its course, and ended up with what you saw for formatting options above.
      07-10-2021, 12:39 AM   #231
baltovacs
Drives: BMW 328dx Sportwagen
Thanks you for the map update!
BadSeed158.00
      07-10-2021, 10:48 AM   #232
Kolianovskyi
Drives: BMW 650i
Thank you for another update.
BadSeed158.00
      07-11-2021, 06:49 PM   #233
ramman434
Drives: F30 335i
BadSeed just wanted to say thank you again! I got that flash drive in today & just successfully updated my maps to 2022-1!
I had to get a new FSC code generated because the 1st one that I had was done for 2021-1 maps. Now I'm good to go!
      07-12-2021, 08:18 PM   #234
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
No problem! Glad to hear it worked out..
      07-13-2021, 10:52 AM   #235
Mike250
Drives: 328i
2022 nbt link
Done
Hi i am interested too please send me a link thanks
      07-13-2021, 11:02 AM   #236
Mike250
Drives: 328i
I am looking for free north america 2022 nbt link, can you pm me the link, Thanks
      07-16-2021, 06:45 PM   #237
mness
Drives: 2013 535iM
The links are in the first post of this thread (NEXT=nbt).
OP, thanks! Updated fine on my 2013 5 series.
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, SAT, Driver Assistance Pkg, Premium Pkg, Multi-Contour Heated Seats, Navigation, H/K stereo. Michelin Pilot Sport 4S non-runflats, M5 grille, Painted reflectors from IND.
BadSeed158.00
      07-19-2021, 09:55 PM   #238
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
@BadSeed thanks so much for the 2022-1 update!!!
2019 Cayenne Turbo
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport
BadSeed158.00
      07-20-2021, 08:19 AM   #239
unluky
unluky's Avatar
7528
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
THANK YOU for posting this!!!
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
BadSeed158.00
      08-05-2021, 05:42 PM   #240
rl2102
Drives: 528ix
Can anyone provide (PM) me an FSC?
D619486
TIA
      08-17-2021, 06:31 PM   #241
altybe
Drives: F15 E89
fsc file
Where do I find the fsc file when I browse in the FSC Generator software?
      08-19-2021, 04:44 PM   #242
dirtydignity
Drives: 2015 BMW X5
Thanks for sharing. Worked flawlessly on the BMW X5 2015. Updated from 2020-2 to 2022-1.
