11-02-2020, 01:07 PM | #1 |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
Remmen Brakes: A possible alternative to BMW OEM CCB Rotors
For any folks with CCB's or looking to get away from rusty/dusty rotors. I have been searching for something to replace my CCB rotors when the fall out of spec. I found these folks https://www.remmenbrakes.com/ that are already making rotors for some exotic cars. I reached out to see if they had anything on the shelf yet for F1x/F06's, but they did not. I replied asking about possibly roadmap for development and got some "promising" info below.
I am in no way associated with them nor am I getting anything in return rather I'm just trying to solve a longer term maintenance concern of mine. Please reach out to them directly for any questions but please add comments below if you do as I am very interested to know if they are going to move forward. From the Remmen Brakes Team: Hi, We are willing to look into for the F06/F10/F13 BMW applications, after a quick research, at OEM size which is 410x38mm front and 396x26mm rear, we would need approximately minimum 15 committed orders (one car set is considered one order) for the program to work, and you would look at approximately $9800 per car set at that volume, excluding shipping costs, it'll require minimum of 95 days for delivery. That includes 4 carbon ceramic rotor assemblies, can work with factory brake pads, or Pagid RSC1 and similar brake pads. Thank you, Remmen Brakes t: 905.985.9848 e: sales@remmenbrakes.com w: www.remmenbrakes.com
11-04-2020, 07:31 AM | #2 |
630
Rep 1,171
Drives: F06 M6
They did mention in another email that they would consider doing a metal rotor conversion kit but I did not get any pricing on that.
11-04-2020, 02:49 PM | #3 |
Rep 582
From what I understand If you dont track the car excessively over 600 degrees the rotors will last the life of the vehicle,Just pad changes Im still on my factory set at 36K miles and they still look thick ,I dont track the car,If you use the car on the street you wont need new rotors
TinCanSailor629.50 |
11-04-2020, 03:55 PM | #4 | |
630
Rep 1,171
Drives: F06 M6
11-04-2020, 08:10 PM | #5 |
Rep 333
Interesting find! What's strange is the OEM CCB rotors are crazy expensive individually (like $4k each), but you can get a full retrofit kit for c.$12k which includes "front and rear pads, calipers, carbon ceramic rotors, brake servo unit, front engine encapsulation, brake air deflector cover, and required hardware". Am I missing something or does that look like a good deal vs c.$10k for just the rotors from an aftermarket co?
11-04-2020, 10:51 PM | #6 | |
630
Rep 1,171
Drives: F06 M6
11-05-2020, 02:30 AM | #7 |
Rep 11,891
Just note, at $9800 for the set, you're near the same price at OEM.($12k for OEM) Now I'm guessing these will be technically cheaper for those who are currently running steel units, as we don't have to retrofit CCB calipers and booster, but, it's not exactly cheap enough IMO.
Flo1989342.00 |
11-05-2020, 02:57 AM | #8 | |
Rep 333
Genuine BMW F10 M5, F12/13/06 M6 M Performance Carbon Ceramic Brake Retrofit Kit - Part Number 34-11-2-317-804 |
11-05-2020, 04:39 AM | #9 | |
Rep 582
90k Miles hywy miles or city , how many miles are cars getting with steel rotors ? I believe CCB set of rotors can last up to 5+ sets longer than steel rotors |
11-05-2020, 10:28 AM | #10 | |
630
Rep 1,171
Drives: F06 M6
Thanks for the share.
11-05-2020, 10:29 AM | #11 | |
630
Rep 1,171
Drives: F06 M6
Mostly Hwy miles sprinkled with some generous city driving. The previous owner had pads replaced at 65k miles.
11-05-2020, 02:25 PM | #12 | |
Rep 333
11-05-2020, 10:33 PM | #13 |
630
Rep 1,171
Drives: F06 M6
I did dig around a bit but only found it cheaper by 100 bux so ya hit gold. I am definitely going to look a little more but after parting out pieces I don't use it could greatly reduce my cost on rotors and pads which will help keep the car in the drive way for many more years.
MMMM6GC275.00 |
