05-22-2021, 11:34 AM | #1 |
Rep 33
M6 Rear window shade
Still trying to figure out the rear window shade.....
Read the owners manual and can’t find any info regarding the rear window shade.....can some one point me in the correct operation of that rear shade.....it is up now and I can’t see out the back window as well as I should.... I’m sure it’s something I have to learn.....just turned the AC on and it took a while for it to blow cooler air.....not cold air....operator error....HD799 military code for operator error.....any help is appreciated |
05-22-2021, 03:21 PM | #2 | ||
Rep 7,449
The button for the rear shade(s) is located on the driver’s door master control switch for the windows. If you briefly press that button it will go either up or down (depending on the position of the shade at the time of the press). If you have powered rear door shades (can’t tell if you have the f06 4dr GC or the f13 2 dr coupe)...then you can also control the two rear door shades using the same button...it just requires a press & hold of that same button. But one thing is required first...and that is to have all of the shades in the same position. For example, if the rear shade is up but the door shades are down...then do a brief press of the button to lower the rear shade. Once all the shades are down...then press & hold the button on the driver’s door and all 3 shades should go up. And if you press & hold the button again, then all 3 shades will go down. But...if you only do a brief press of the button...only the rear shade will go down or up. In the pics below of the rear window shade...the last pic (from the owners manual) shows the instructions for:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-22-2021 at 09:16 PM.. |
05-22-2021, 04:10 PM | #3 |
Rep 33
QSilver7
Thank you .... I will try all of this when I get off work today.... I hate it when you get another vehicle and have to relearn all of the features of the vehicle ...but change is good .....just figuring it out is the embarrassing part. Much like when I taught people how to drive on Race Tracks.... General I Salute you and Thank you. |
