07-31-2018, 06:57 PM | #1 |
Rep 3,071
Extended Warranty and Timing Case Cover Gasket Repair
Dealer discovered oil leak from timing case cover. Engine was removed and besides timing case cover, they removed cylinder heads and replaced both gaskets ($316), plus all 8 RP Injectors ($281 each), Turbo Coolant Line Repair Kit ($47.80); 2 AIR INTAKE TUBES $(136.90 each); 10 quarts of oil (9.40 each); Oil Filter ($26); 4 quarts coolant ($9 each)
Parts alone are over $3,000 Labor is unknown. All for $50.00 under extended warranty. Well worth the $5200 it cost.
My Car Photo Blog: http://carfisheye.blogspot.com/ |
07-31-2018, 07:16 PM | #2 |
Rep 238
Drives: BMW M6 comp
Garage List 2019 Aprilia RSV4 [0.00]
2015 Land Rover Ran ... [0.00] 2014 MV Agust Rival ... [0.00] 2009 KLR650 [0.00] 2016 Kawasaki KX450F [7.50] 2016 BMW S1000RR [8.50] 2014 BMW M6 [8.00] |
jeeez
TomM674.00 |
08-01-2018, 06:59 PM | #4 |
Rep 966
That's awesome.
Extended warranty is always a nice to have in scenarios like that. The tech got paid ! BMW Labor guide states 35.7 MFG Warranty - 48.5 Standard Auto Trans Both Banks A 35.7 48.5 Includes: R&I Cylinder Head, Transfer All Necessary Components, Grind All Valves & Make All Necessary Adjustments. |
08-02-2018, 06:46 AM | #5 |
Rep 3,071
Please translate: BMW Labor guide states 35.7 MFG Warranty - 48.5 Standard
09-11-2018, 11:02 AM | #6 | |
Drive slow
Rep 26
09-12-2018, 04:43 PM | #9 |
Rep 3,071
2013 with 61k miles. Mike Miller of Roundel says heat is the cause of gasket failure.
Tags |
timing cover gasket |
