      10-17-2020, 07:38 AM   #1
mjposner
mjposner's Avatar
Drives: 2016 650i F12
Folding Top Cover damaged/stained
My Folding Top Cover has a white stain from where the top meets the cover, presumably from sitting outside with the top up in the hot sun.
Has anyone repaired this, looks terrible when top down. Can it be resprayed. It feels like vinyl.
Retails for $650 new.
Name:  top cover.jpg
My other rides: 1965 Chevrolet Corvair Corsa and 2007 Porsche 911s
      10-17-2020, 10:01 AM   #2
Opie55
Drives: '15 650i Convertible
Mine sits in the sun 365 days a year and has not done that. If the stain is permanent, yes, it is vinyl. So I presume it could be sprayed black again.
      10-17-2020, 07:27 PM   #3
Alpine650
What part of the cover? I have some white marls from the top on mine. I think it is dried in soap from the car wash. One spot I never thought to dry. Here is a link to my Post with pics:
https://www.6post.com/forums/showthread.php?t=1754920
      10-18-2020, 08:09 AM   #4
mjposner
mjposner's Avatar
Same. Its obviously from the top resting on the cover when up. Will take pics today, try and clean and see how it goes. Looks like crap when top down.
      10-18-2020, 08:50 AM   #5
patchesj
patchesj's Avatar
42
Drives: BMW M6
So I had my car coated by a shop that uses all Fenylab products. I have a bottle of their quick detailer, and I was noticing a similar issue on my car after washing it. A little bit of soapy water would get under the top and create white water spots that wouldn't wipe off. Quick detailer to the rescue... Sprayed on, wiped off with microfiber.
https://www.feynlab.com/product/feynlab-detailer-v3/
      10-18-2020, 01:11 PM   #6
Alpine650
I used Aerospace Protectant 303 at the suggestion of another forum member. Used it with a soft bristle brush. One side is almost back to normal. The other side not much of it came out.
      10-26-2020, 06:44 PM   #7
mjposner
mjposner's Avatar
Here is what mine looks like now:
Name:  cover stain one.jpg
Name:  cover stain two.jpg
      10-26-2020, 06:45 PM   #8
mjposner
mjposner's Avatar
My Covers now
      10-26-2020, 07:20 PM   #9
Luftpost
Drives: 2016 650 GC X, E39ís, X70
Looks to me like a calcium deposit. Perhaps some kind of a chemical reaction or intolerance between the two materials. Kind of late now, but I would certainly treat those surfaces with a good protectant as mentioned in a previous thread.
L.
      10-26-2020, 10:53 PM   #10
Opie55
If it is hard water, maybe try vinegar. It almost looks bleached.
      10-27-2020, 07:24 AM   #11
mjposner
mjposner's Avatar
I am the second owner. The prior owner was rough, the steering wheel was shot, the door arm rest is worn, the door sill plate has small damage, even the center console button has some damage. Typical 3 year lease car with non-caring owner. If top is put down when raining, or i, water gets between top and cover. I suspect that is hard water stains. Will go at it shortly.
      11-01-2020, 05:54 PM   #12
mjposner
mjposner's Avatar
Used Vinyl Cleaner and then Vinegar with brush, not much change, Goo Be Gone Spray worked better (https://www.amazon.com/Goo-Gone-Adhe...271247&sr=8-10)
Name:  cover stain cleaned.jpg
      11-02-2020, 11:13 AM   #13
Derekz4
Drives: BMW 640i. BMW Z4,01 Bullitt
I had a Z4 where the previous owner was a female, her makeup stained the crap out of the steering wheel. It looked white and no leather cleaner was working for me. Someone suggested mr clean magic eraser and it worked fantastically.
      11-02-2020, 07:31 PM   #14
mjposner
mjposner's Avatar
I have tried that mr clean magic eraser on many things and it mostly fails
      11-02-2020, 09:26 PM   #15
Alpine650
Thanks mjposner. I'm going to try the Goo B Gone Spray.
      11-03-2020, 07:19 AM   #16
mjposner
mjposner's Avatar
Also, clean the rubber on the wing side with some gummi pflege, if its kept clean and supple maybe it won't stain as much
      11-03-2020, 04:45 PM   #17
Alpine650
By wing side I assume you are saying the same spot? After cleaning with Goo Gone treat that area with this stuff to keep it from happening again?
      11-03-2020, 05:10 PM   #18
mjposner
mjposner's Avatar
No on the top itself, it has a rubber seal that sits on the cover and causes the stain
      11-06-2020, 07:30 PM   #19
Alpine650
Tried Goo Gone on white marks - no change. Also, mjposner what color is your car. I ask because the pics above from 10/26 look tan then the pics on 11/1 look black?
      11-07-2020, 07:33 AM   #20
mjposner
mjposner's Avatar
Its black. I have a tan canvas carport at my office where I took the first picture which changed the light.
      11-17-2020, 07:22 AM   #21
mjposner
mjposner's Avatar
Well white stain is back. Not sure whether to try and respray with vinyl paint or replace.
      11-19-2020, 05:29 PM   #22
Alpine650
I wish we could figure out the cause? I thought it was left over soap after car wash but that should be easy to get out.
