      10-17-2019, 12:38 PM   #1
Oak_M6
Drives: M6 Convertible
Soft close door question!!!!
Soft close door broken, doesn't work and make loud noise when door close. If I don't want to replace it, can I try to disconnect the unit or just remove the part? Thank you!!!
Lixiao Zhao
      10-20-2019, 08:24 AM   #2
Info from the TIS says that the "soft close drives are not connected directly to a control unit"...which means if they were to be disconnected...there wouldn't be any warning message sent etc.. And you can see in the illustration (below) taken from the link provided...that the soft close drive is separate from the door lock.
There's also a diagram that shows the drive and its electrical connector locations. If you decide to pull the power and it works...please post back your results (in this thread) to give back and others that may want (or need) to do the same thing.
You can read the operational function of the soft-close doors at this direct link to the TIS (I suggest reading the whole page) to see if this will work for you: https://www.newtis.info/tisv2/a/en/f...system/XeJHqp1
BMW CCA Member #191509
      10-22-2019, 07:56 PM   #3
Bimmma
Bimmma's Avatar
32
Drives: E92 M3, F06 M6
Please do share feedback if the problem is fixed. My drivers door soft close has also stopped working. Not sure if itís the actuator motor or the lock assembly. When the door closes I can hear what sounds like the motor running though. Removing the door panel also seems like a little mission to take apart to troubleshoot whatís going on, but one of these I will try to get around to doing it.
      10-27-2020, 02:21 AM   #4
howe9191
howe9191's Avatar
Malaysia
Drives: 2013 F13 M6, 2013 F30 328i
https://vimeo.com/472487264
      10-27-2020, 02:22 AM   #5
howe9191
howe9191's Avatar
Malaysia
Originally Posted by howe9191 View Post
Hi guys, my door has got this issue when closing. Need Help!!
      10-29-2020, 09:44 AM   #6
phan
Drives: X5 35d, M5 SC'd, M6GC
i had to replace the motor/unit to fix. no errors, just that sound posted in the video above.
      11-06-2020, 09:50 AM   #7
HeyKC
Drives: BMW M6 CP
I found this on Youtube if anyone wants to do their own. Not the best DIY but good info.
      11-23-2020, 05:36 PM   #8
KauvSTi
Super Member
KauvSTi's Avatar
109
Drives: M6 Comp, M8 Comp, S63, 600LT
If you don't care for the soft close option you can just unplug it and everything will work as normal. Just did this on a buddies F10 M5.
DME Stage III, Catless Downpipes, SSP Basket & Clutches, 3.5" Custom Intakes & Eisenmann Race Exhaust
      11-26-2020, 02:12 AM   #9
howe9191
howe9191's Avatar
Malaysia
Only unplug will do? no need do coding right?
Thanks bro for your assist
