      04-18-2020, 09:56 AM   #23
MichaelInChicago
Drives: 2015 BMW 650xi GC
Over the last week I changed the plugs (NGK Iridium 97506), changed the oil and filter, both air filters, the cabin filter, cleaned both MAF sensors and had my local BMW dealer top up both coolant reservoirs (they also gave me a half filled jug of BMW coolant to have if I ever need to top it up again).
The car is definitely running smoother, faster, breathing a whole lot better and even the sounds are more intense and inspiring.
I guess it is true. Proper maintenance is definitely important
      04-26-2020, 11:39 PM   #24
chukd23
Drives: 2015 M4
I guess Im the only one having issues, I changed my plugs to the NGK and the car is running rough as hell, the plugs I took out were the Bosch ones stamped with the BMW letters
      04-27-2020, 12:37 AM   #25
pdubq
pdubq's Avatar
57
Drives: 15 650ix GC, 14 X35i MSport
Originally Posted by chukd23 View Post
I guess I’m the only one having issues, I changed my plugs to the NGK and the car is running rough as hell, the plugs I took out were the Bosch ones stamped with the BMW letters
Did you happen to gap them down at all?
I followed bm3 recommendation: https://bootmod3.atlassian.net/wiki/.../pages/2558945
97506 plugs at .022-.023” gap.
Or maybe your coil packs could stand to be replaced as well?
After battling wandering misfires and hesitations on past bimmers when I diy’d the plug and coil pack replacements, I’ve decided a while ago that I’ll save myself the trouble, pay a little more, and just always do them all together.
2015 650iX GC, S1 BM3, black M-style grille
2014 F25 xDrive35i MSport, VRSF High-flo catted Downpipe, VRSF FMIC, VRSF Charge pipe, aFe Magnum intake, BM3 Stage 2, xHP Stage 3
      04-28-2020, 07:37 AM   #26
Ptoscano911
Drives: 2015 Bmw 650i xdrive GC
Originally Posted by TGrits10 View Post
Installed the plugs yesterday, still need to do a closer inspection/analysis of the old plugs and get feedback from more varied driving conditions (so far I've taken it around the block post-install and drove to work this morning), but I've yet to feel a miss happen so that's...good? Anyway quick thoughts:
-Pretty easy, even the front cylinder on each side was no problem, hardest thing was getting the intake boxes back in just the right position to reconnect the rubber hoses.
-Total time including putting away tools after = ~2 hours.
-The bracing bars have a 15mm bolt on one end and a 16mm bolt on the other. WTF/whatever man.
-Took advice on the plug socket from FCP Euro not wanting to release and sprayed some WD-40 inside before I started. Worked beautifully. Used 6" + 3" extensions on most, 6" + 6" front cylinders.
-MFer those long threads put years on my life awkwardly leaning over the engine bay whipping the ratchet handle 90 degrees at a time.
-The new plugs all measured about a 0.028" gap out of the box, fwiw. I didn't mess with it.
-Old plugs coming out I measured a couple at 0.032-0.034" and then said screw it, analyze later. Didn't see anything obviously bad, will measure/examine the rest later.
-Patient is a 2015 n63tu @35k miles exhibiting stumbly cold starts, slight rough idle, and intermittent missing under load. Fingers crossed.
Do you need a universal to use ? I hard plugs are angled ?
      04-28-2020, 01:30 PM   #27
doggboy
Drives: BMW 650i
No universal is needed on the 650, just a couple of extensions.
      04-28-2020, 02:24 PM   #28
board57796
Drives: 2015 650i Gran Coupe
Changed mine a couple weekends ago. Like the other poster said, the most difficult part was getting the air box tubes snaked back into place and connected. The spark plugs and coils were a breeze. I did use a swivel between the extension and spark plug socket for the farthest forward ones, but I don't think it was 100% necessary.
      04-29-2020, 09:13 AM   #29
TGrits10
Drives: 2015 650i GC
Yeah for the two front cylinders it would've been easier with a swivel, but with an extra extension the tight quarters were mitigated.
      06-30-2020, 06:26 PM   #30
C-Poppy
Drives: 650i xDrive Gran Coupe
Originally Posted by doggboy View Post
You want to keep the gap as close to stock recommendations as possible. The smaller the gap the less energy. People gap down because higher boost has a tendency to "blow out" the spark if gapped too wide on our cars, which is why people gap it down to 0.018-0.022. For stage 1 I wouldn't gap it down that far. I am at 0.025 on BMS map 2 with E30 and I have no issues.
This is surprising as everything I have read, including recommendations from Burger, says that they are two steps colder than stock. I wonder if anyone will chime in that is running them on a stock motor, but I wouldn't do it.
The NGK 97506's are 1 or 2 step cooler for certain engines but for the N63TU... they are a direct replacement. Hope this helps...
      06-30-2020, 07:01 PM   #31
doggboy
Drives: BMW 650i
Not according to their temperature chart. The 95770 (range 7) is the direct replacement and has a much wider heat range than the Bosch. The 97506 (range 8) is 1 step colder according to their chart.
      07-22-2020, 11:33 AM   #32
C-Poppy
Not if you use the correct charts.
      10-27-2020, 12:11 PM   #33
pits200
Drives: 09 335i X-Drive Black Sapphire
Not the same heat range, ngk is 1 step colder....
