      09-06-2020, 10:39 AM   #1
elvisisdog
Drives: F06 MSport 2013/09
640D coolant low
Has anyone noticed coolant consumption on their 640d? I've had the edge recall done which happened to coincide with the last time I had low coolant. I'm wondering if the egr is playing up again. No signs of issues around the engine, oil is as normal, no leaks.
      09-17-2020, 06:21 AM   #2
nigelharbron
Drives: 2012 640d MSport
Hi elvisdog, just bought mine and a week later it needed around a litre of water, it came serviced so I didn't check the levels on purchase and am now wondering if coolant usage is normal on these? Anyone else having this problem? TIA
      09-17-2020, 11:33 AM   #3
rasa bmw
Drives: space grey 640d sport e90 330d
nope,,
      09-20-2020, 06:19 AM   #4
MARKPRIOR
125
Drives: 2014 640D
Have you had botg EGR recalls done? Some cars have x2 recalls (one for the cooler & one for valve from memory)
      09-21-2020, 02:28 AM   #5
Mark333032
Mark333032's Avatar
32
Drives: 2015 640d MSport Gran Coupe.
I was using a small amount of coolant until I had teh EGR recall done about 4 weeks ago. Since then I have lost zero coolant
      09-21-2020, 09:03 AM   #6
elvisisdog
I've had one of the recalls done, I thought it was the egr. Had a similar issue when the egr recall came through. Idrive came up with warning coolant was low. After the egr recall though I had no issues. I'm just wondering if the recall had put a similarly bad product on?
Surprises me how low the coolant had to be to trigger a warning. Mine was well below the minimum line in the expansion tank.
It's due a service next month so will give them a call and get them to check recalls on the car.
Thanks..
      09-21-2020, 11:59 AM   #7
rasa bmw
it's the egr cooler which the recall is for..mine had one in 2015 and another one in march,,it is now an upgraded part,,2015 one was like for like
