      12-30-2020, 02:03 PM   #1
Akaf1
Drives: Bmw 650 xi gran coupe
2017 650xi GC Tire Size
I have the above referenced model and needed to replace the stock tires as they were summer tires and I live in NY. Opted for Pilot Sport A/S 3+ from tirerack, however the rears have been backordered for a month and no date in site for delivery. The OEM tires are 275/30/20 in the rear and that is the size that are backordered. They have a set of 275/35/20 in stock, however said the 35 vs. 30 might not fit or could cause rubbing on the wheel well. Any advice? I have the new A/S on the front but am still running the summer tires on the rear and don't want to go too much further in to winter on them. Thanks
      12-30-2020, 04:27 PM   #2
Walt White Coupe
Walt White Coupe's Avatar
222
Because you have an "X" drive, the circumference of the tires are critical and you have to stick with the original sizes or you will prematurely wear out your transfer gear box even if they do fit.
      12-30-2020, 09:50 PM   #3
AccordTR
AccordTR's Avatar
As said definitely a no go. The rolling circumstance will be too different and cause transfer case issues.
M Sports Edition
Carbon Wing
Carbon Front Splitters
Carbon Rear Diffuser
Carbon Grilles
CPG intakes
Arm catless downpipes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
