02-01-2018, 12:43 PM | #1 |
Joint Chiefs of Staff
23784
Rep 190,128
AR Design 640 Downpipe
We are thilled to present our new F-chassis Hi-Flo™ Resonated Catless downpipe for the BMW N55 engine! The only downpipe on the market with a large resonator to help tame rasp and drone! In addition to an intoxicating and exotic sound, these downpipes add significant power and help eliminate turbo lag! Fitment for the following cars: F06 640i Gran Coupé F10 535i Sedan F12 640i Convertible F13 640i Coupe Our Hi-Flo™ 3" Catless Resonated Downpipes Feature: Typical gains with tuning in the 20+whp range! 3" Race Resonators helps tame annoying exhaust rasp without impeding flow. 100% hand crafted in the USA from premium 304 Stainless Steel - flanges and O2 bungs included! CNC'd 304 Stainless V-Band flange. 100% TIG welded, argon back-purged. Available with a 2000°F ceramic coating. Coatings come with a 3 year warranty against corrosion and rust to original owner. Lifetime warranty against any manufacturing defects given to original owner. We do NOT grind/polish our welds as some other manufacturers do. Grinding welds compromises the strength of the weld, and can lead to weld failure! Especially critical in applications exposed to temperatures in excess of 1200°F. Such temperatures will also rapidly deteriorate the polished finish. More information on our Ceramic Coatings The coatings we offer are capable of withstanding temperatures of 2000°F. In addition they offer excellent chemical and corrosion resistance and possesses excellent thermal barrier characteristics, providing a dramatic reduction in radiated heat. This means reduced under-hood temperatures, accelerated exhaust gas velocity and a longer life expectancy for the downpipes. Ceramics stand above all other thermal barrier coatings currently being used in combustion chambers. Ceramics have characteristics shared by no other product, providing an unrivaled layer of thermal protection to piston tops, aluminum heads, stainless, iconel and titanium valves. Ceramics "move" heat, reducing detonation and increasing the effective oxidation of fuel. When polished, it provides a highly reflective surface that further aids in improved flame travel. Unlike previous ceramic coatings, ours is not subject to cracking and flaking, which can lead to extensive engine damage. In fact, Ceramic coatings actually strengthen the coated part. The cured "Cermet" provides a cap of material that can withstand far more heat. During testing when sufficient heat was applied to a piston to melt the aluminum, the Ceramic did not melt, rather it held the softer aluminum together. The Satin Ceramic Exhaust Coatings we offer are the most advanced exhaust system coatings available. They are a very durable ceramic-reinforced coating available in various shades. When properly applied, it becomes the most effective thermal barrier coating available, increasing performance while extending component life, and has been tested to over 2000°F without lifting, cracking or flaking Catless Catted
Check out our current sale by clicking on this link!
https://x-ph.com/sale/ Phone number 702-494-9435 |
10-16-2019, 01:39 PM | #2 |
23784
Rep 190,128
Resonated 535/640 AR Design Downpipe
10-18-2019, 10:25 AM | #4 |
23784
Rep 190,128
It is! check your inbox
11-11-2019, 06:17 PM | #6 |
Rep 788
Thanks |
11-11-2019, 06:49 PM | #7 | |
23784
Rep 190,128
In order take full advantage of this mod, i suggest you pair it with a flash tune
11-15-2019, 02:06 AM | #9 | ||
Rep 788
11-15-2019, 11:07 AM | #10 |
23784
Rep 190,128
Bootmod3 is the most popular option
11-15-2019, 05:50 PM | #11 |
Rep 788
11-16-2019, 11:08 AM | #12 |
23784
Rep 190,128
Its $595 for bm3 ... For loudest sound , get catless. For a quieter increase an no fuel smell get catted pipes
01-15-2022, 10:38 AM | #13 |
Rep 3
01-15-2022, 01:15 PM | #15 | |
23784
Rep 190,128
your account is brand new and does not accept private messages Please call me at 702-494-9435
01-16-2022, 11:02 AM | #18 | |
23784
Rep 190,128
it depends on your state's laws
01-16-2022, 01:43 PM | #19 | ||
Rep 788
01-16-2022, 03:14 PM | #20 |
Rep 3
01-16-2022, 05:17 PM | #21 |
23784
Rep 190,128
We are open Monday to Friday, 9am to 3pm Pacific time.
