05-24-2021, 08:46 PM | #1 |
Rep 85
Tow Hook Cover
Anyone know where I can buy a tow hook color that will match the alpline white? Mine flew off somewhere...
https://share.getcloudapp.com/8LuoBg2g |
05-25-2021, 04:56 AM | #2 |
Rep 39
I lost my front one
https://www.paintedoemparts.com/stor...QaArFrEALw_wcB Found this web and about to order, not sure how good are the paint, but for such small part should be alright. |
05-26-2021, 12:38 PM | #3 |
Rep 7,468
You could go to your local BMW dealership’s parts department and have them order you one...or go to one of the online part databases and pull up the diagram to get the 11 digit BMW part number and look for it online (used in the color you need) or new & primed (to be painted later). You could then look locally for someone to paint match it...or go online and buy a can of spray paint based on the color code on your VIN sticker...and you could spray paint it yourself.
You need #5 in the diagram below: I purchased a can of space gray paint from either an eBay or Amazon.com vendor that was based on my exterior color code A52 (space gray) and it was a perfect match. You could do the same for your exterior color...just make sure you use the correct exterior color code...again found on your VIN sticker in the lower right corner. Once you have the correct color code...just type BMW “XXX” spray paint (where x=the actual color code) into an eBay or Amazon.com search box. You can see the exterior color code in the pic below...look for A52/7 in the lower right corner...A52 is the exterior color final coat and the 7 is the base coat color in this example
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-26-2021 at 12:56 PM.. |
06-07-2021, 02:15 PM | #4 | |
Rep 85
06-07-2021, 03:49 PM | #5 |
Rep 7,468
Sorry about that…but your link doesn’t work (for me) and your original post didn’t say which one was missing (front? or rear?)…so I just took a stab at it being the front.
Everything still applies, though…you just need to go to the rear bumper diagram to get the correct part number for #2 of the rear M-bumper diagram.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-07-2021 at 03:55 PM.. |
jjasonSU194.00 |
