06-03-2021, 04:05 PM | #1 |
New Toy for the Sun
Rep 3
2015 650i Exhaust Tip Replace
Previous Owner Crunched the driver side exhaust tip.
Help, I need ideas on fixing or replacing the tip. No other damage to exhaust. Dealer says Integrated into exhaust system so replace entire system on that side, I said ouch to $2800. The exhaust Pipe is really strong/hard. So: 1. Grind / Cut both tips off and replace with something else 2. Grind / Cut out part of both pipes so look the same 3. Find a pipe bender to straighten out the one 4. ??? I'm open. BTW I also have a new diffuser to replace the scratched one in the pic but plan to do everything at once. |
06-03-2021, 05:01 PM | #2 |
Rep 404
Where are you located? I have a set of stock m-sport mufflers and m-sport diffuser i dont need.
Or you can do this... https://www.6post.com/forums/showthread.php?t=1317986 |
06-05-2021, 08:15 AM | #6 | |
Rep 285
06-05-2021, 09:31 AM | #7 |
Rep 451
Yeah man been there. See if they will order u one. It's $850. Had to be ordered from Germany.
Pic of my car with bumper removed https://www.ecstuning.com/b-genuine-...t/18307629137/ |
06-05-2021, 07:44 PM | #8 | |
Rep 41
If you really like that look then the other poster on here was right, they are a pretty expensive piece to replace and a bear to take off neatly. If you are indifferent and dont mind a different look then I would shop them out and put new tips on. |
06-08-2021, 12:59 PM | #9 |
Rep 287
Ive seen the tip alone being sole online somewhere. i would cut the old one and weld a another one. not sure if it was black. but 80 bucks to powdercoat is a no brainer
