      07-13-2020, 09:45 AM   #23
hart07
Drives: BMW 640i f13
Will try to pop out the engine cover tonight cause it's just clips
Perhaps I Will see better
      07-13-2020, 11:32 AM   #24
hart07
Any help
Thks
      07-13-2020, 02:55 PM   #25
hart07
No idea what's going on
Ccv?
Pcv?
Gasket ccv ?
      07-13-2020, 06:28 PM   #26
hart07
I removed the cover engine to see if there is oil somewhere but nothing
      07-14-2020, 04:13 AM   #27
DaveS86
Drives: BMW 640I
It's normal for turbo vehicles to burn a little oil. That seems in spec to me. I add a litre about every 8000 miles as well, nothing to worry about.
      07-14-2020, 06:25 AM   #28
hart07
Yes but I think it's a little bit more for me no?
      07-14-2020, 08:00 AM   #29
DaveS86
Drives: BMW 640I
I honestly wouldn't worry about it!
      07-14-2020, 12:04 PM   #30
hart07
I hope
      07-16-2020, 12:16 PM   #31
hart07
Curious oil indicator
Today I was running the car during 15/20 minutes and I check the oil and I see almost max level just below the max level.
And at the end of the day the car stayed 30 minutes off and after 20 minutes again running the car through city and speedway and I see only one bar up the low level.
Curious is my sensor oil in default or not?
Any thoughts?
      07-17-2020, 09:00 AM   #32
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
If you are not getting a consistent reading, it would be advisable to change the oil level sensor at the next oil change. Since we do not have dipsticks, it is not worth taking a chance. If you miss a low oil pressure alarm that could be costly. (This is of course assuming you were on a "perfectly" level surface when the readings were taken)
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      07-17-2020, 01:05 PM   #33
hart07
Like I said above yesterday I ran 20 minutes, I launch an oil level and I got almost max just below the max.
I come back at home after 20 minutes I let the car about 25/30 minutes I ran again for 20 minutes I go back at home I let the car 20 minutes and I launch an oil level and I got just above the low level.
Very curious no?
      08-10-2020, 09:33 AM   #34
hart07
Since 163000 kms I ran 2000 kms now at 165000 kms I got message add 1 liter oil
Is it normal for you?
Got no leak
No smoke on the exhaust (just when weather is cold or rainy at start)
The car is running normal
      08-11-2020, 05:33 PM   #35
hart07
Any help cause don't know if normal or not
And what's to do I mean where I can control if there is a leak or other
      08-12-2020, 03:12 AM   #36
hart07
I got the message when I run only never at start
It's easy to change the oil sensor how much in shop?
      08-12-2020, 10:41 AM   #37
arucano
arucano's Avatar
It is very easy when you are changing your oil (you do have to drain the oil).
https://www.newtis.info/tisv2/a/en/f...ensor/H74mIjTZ
https://www.newtis.info/tisv2/a/en/f...splay/FAYVhEty
enjoy
      08-12-2020, 08:13 PM   #38
hart07
Thks but don't know if this the oil sensor the problem
I hope
      08-12-2020, 10:30 PM   #39
arucano
arucano's Avatar
I hope
The only other (not likely scenario ) reason is that you have so much sludge that is is plugging the rundown (oil return passages) to the crank case. This is HIGHLY unlikely. The only thing that measures the oil level is that sensor. If you end up overfilling the engine because of a bad indication, you could damage the engine. Needless to say that a false OK level can also mean that the oil level is too low. I would STRONGLY advise against taking any chance $$$$$$ of damaging your engine and change the oil level sensor.
      08-15-2020, 04:11 AM   #40
hart07
Yes you're right
It's common to change oil sensor on F13
Mine got 165000 kms now
      08-15-2020, 04:13 AM   #41
hart07
I got one leak it was in February on the oil filter gasket housing.
I changed it in February only the side where was the leak.
      08-15-2020, 10:31 PM   #42
hart07
If it's not the oil sensor my problem what it could be?
The oil level warning is only when you're stop with the car or when you're running?
Cause me it's only when I am running with car.
Last time at 165000 kms the oil level warning asks me 1 liter, I add only 2x 1/4l and the level was almost at max.
