      06-08-2021, 03:24 PM   #23
ex46fanatic
That was easy. Passenger side same as driver. Power to pin 1 required.
Tomorrow will tackle rear seats.
In the mean time please advise on what I need to code if anyone knows.
      06-08-2021, 06:18 PM   #24
ex46fanatic
Struggling for info on how to reset the restraint system. Have fault for both seats.
Edit. Ista d isn't clearing it because of the belt and retractor tensioner codes
      06-08-2021, 08:36 PM   #25
ex46fanatic
Have installed e sys but not tested or connected yet - and got ista d to connect to the car using the new cable.
Left to do - clear restraint system faults, code/register stuff, proper wiring to pin 1 on seat connectors.
Tomorrow rear seats will be done -should be a doddle.
      06-09-2021, 04:47 PM   #26
ex46fanatic
Went to independent dealer to clear restraint system faults. It wouldn't clear. (He had the ability to clear it).
Tomorrow swapping belt tensioners over from my old seats. Maybe airbags as well. And then will try clearing codes.
Come to think of it i did feel the belt tensioners were positioned low when i was buckling up. Theyve probably deployed.
      06-10-2021, 10:08 AM   #27
ex46fanatic
Got a few codes to clear. Seat belt tensioners were replaced. I have codes for retraction tensioners as well. Looks like I need to swap over that part as well.
I guess the seats were involved in an accident but side airbags did not deploy.
Below is the code after I swapped driver side belt tensioner only.
Am pleased these are the only codes I have ! All related to the new seats
      06-10-2021, 01:27 PM   #28
ex46fanatic
Removed retractor tensioners from both old seats. Wasn't very difficult.
Have to do other stuff now. Will get them fitted over the next few days
Getting closer to a proper install! Also put in the proper BMW pins for pin 1 on seat connector. Will advise on part numbers for others who want to try this retrofit.
      06-10-2021, 07:26 PM   #29
ex46fanatic
On a long drive back - driver seat heating stopped working, everything else powered... today was the first time i used it and i noticed it felt a bit too hot for the lowest setting.
Hope its not the element !
      06-11-2021, 03:42 PM   #30
ex46fanatic
Heated seat part started working today... I won't be trying it again until the other codes are cleared. I suspect high resistance in retractor tensioner is sending more amps to other areas. Don't know.
At least it's not the element.
