      07-07-2021, 08:59 AM   #1
phan
Drives: X5 35d, M5 SC'd, M6GC
Rear Sunshade Won't Retract
Per the title, my rear-most sunshade simply won't retract while the two rear door sunshades are working fine. There's no sound or anything like that, it simply went up after working perfectly fine and won't retract at all. While the threads I found weren't M6 specific, it seems as though it's a common BMW problem with the power shades, and it sounds like the motor might have have just gone out?
Has anyone experienced this? If so, what was the issue and ultimately, the fix?
TIA!
      07-07-2021, 01:20 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
Try using something like Bimmerlink to determine whether there are any codes set. BTW, a standard OBDII reader will not show these codes. I have had a few cases of codes being set that then disable a function. After clearing the code, the functionality was restored. If the fault is real, it will re-appear as soon as you try the function and you will have to fix whatever the fault indicates.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      07-08-2021, 02:44 PM   #3
HeyKC
Drives: BMW M6 CP
Have someone push the button while you fold it down. Try some WD40
      01-05-2022, 04:40 PM   #4
Gotyour6
Drives: BMW M6 (F06)
This is what I had to do
