      07-31-2021, 07:59 PM   #1
sueddo
Drives: BMW F10 550i, BMW M6 GC
M6 GC M-DCT Transmission service?
Hey everyone,
went to my local BMW dealership for a general service on my 2017 BMW m6 gc with M-DCT and they read a transmission service overdue on my key fob. Currently got 39,000 miles on the car and from what I read the transmission fluid is a lifetime fluid on a M-DCT and should never be touched. I also read that certain dealerships have been recommending transmission services but it is not required / recommended by BMW corp.
Anyways Got quoted 2.3k for the transmission service alone but got it down to 1.4k with a independent BMW service place which is still incredibly expensive.
Anyone ever come across this? Thanks in advance! Sorry if posted in wrong place, still new to this forum.
      07-31-2021, 10:26 PM   #2
Kamate
Drives: BMW m6
If the independent shop going to change all the filters and the transmission pan then $1400 sound about right. Maybe just a tad on the high side but not by much.
      07-31-2021, 11:23 PM   #3
sueddo
Thanks! How common is a transmission service keyread anyways? Looked all around google and found no videos or forum posts about such thing. Hopefully once this is completed i'll never have to do another trans. again, going to make me broke.
      07-31-2021, 11:42 PM   #4
arucano
arucano's Avatar
2014 BMW M6 GC  [0.00]
just type in BMW dct filter change" into YouTube. There are several posts that should give you an idea.
Sapphire Black Metallic
The drive is the destination
      07-31-2021, 11:58 PM   #5
Kamate
Drives: BMW m6
For me personally, I do transmission service and rear differential fluid every 50k for all of my vehicle.
      08-02-2021, 01:09 PM   #6
LJohnson32
LJohnson32's Avatar
Drives: 2016 BMW M6 Gran Coupe
Technically the transmission and fluid are considered 'lifetime' by BMW which equates to 100k miles -- but I have been contemplating doing one on my car anyways. My local BMW dealership quoted me ~$650 for the job but I also have a good relationship with my advisor. If you're thorough with the job, the parts are about $580. I'm not sure if this is the exact parts list that BMW would replace/change during the service though.
      08-04-2021, 11:15 AM   #7
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
Drives: a BMW
Or maybe lifetime refers to the lifetime of the original warranty?
I'm in the camp that believes if you want to keep the car for a long time, a periodic transmission fluid & filter exchange will be money well spent.
G82 M4 w/3 pedals
F22 M240ix (hers)
G30 M550ix awaiting allocation
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G30
      08-04-2021, 11:19 AM   #8
LJohnson32
LJohnson32's Avatar
I've confirmed with my service advisor that 'lifetime' does refer to 100k miles, engine coolant also falls into this category as well.
I agree with your philosophy though, I change all fluids at about a 2:1 ratio to BMW's recommendations as I believe it is a relatively inexpensive way to prevent expensive issues long term
      08-07-2021, 08:50 AM   #9
Aliendex
Aliendex's Avatar
Italy
37
Drives: M6 F06
I've done a DCT service in my M6 a month or so ago.
It's actually pretty simple and straight forward.
You don't need the drain plug if you buy the oil pan because it's included.
What i have bought:
28107850148 (pan filter)
28107842840 (pressure side filter)
28108070791 (oil pan with drain plug included)
28107850241 (filling plug, highly recommended because it uses a silicone o-ring, better to replace it for 10$)
Less than 300 for everything, then about 100 for 8 liters of Motul Multi DCTF oil.
After draining and changing the filter and the pan, use ISTA for the adaptation to fill back the exact quantity of oil (you will drain ~7 liters of oil, and you will be able to fill only 4 liters without the adaptation procedure)
The old oil was not bad but it contains some small metal particles, also found some in the magnet inside the oil pan, so I'm suggesting to do a service)
My car is at 70'000km or about 43'500 miles
Cheers
      08-20-2021, 12:22 PM   #10
sdlsky18
Drives: 2014 m6 coupe
DCT service / new oil pan?
Hello! Im new to M6 family, its 2014 M6 coupe with 58k miles. Stock no mods.
My shopping list for first time DCT service:
oil pan drain plug
Pentosin FFL-4 DCT fluid 5 litter
BMW DCT oil pump filter
BMW DCT Mechatronic Unit Cover Gasket
BMW DCT filter
BMW DCT fill plug
I see some DCT service kits include oil pan, some not. Wondering if it's necessary for me to get a new pan since I have gasket on the list already. Or is there any other concern that I'd better get a new pan?
Thanks!
      08-20-2021, 12:29 PM   #11
sdlsky18
What i have bought:
Cheers
do i have to get new oil pan or i can just replace gasket instead?
      08-20-2021, 03:01 PM   #12
Kamate
Drives: BMW m6
You can reuse the pan. I recommend you to get 7 quarts and new pan bolts.
      08-24-2021, 03:30 PM   #13
Aliendex
Aliendex's Avatar
Italy
37
Drives: M6 F06
If you are able to find the gasket (good luck!) because it's a special gasket.
It's usually better to change for a new oil pan, because of the gasket and because it's made of plastic and can warp with heat cycles.
