      03-01-2021, 05:19 PM   #1
NGROSSO
Drives: 2017 Alpina B6 -- 2016 M6
Rebuilding M6 / S63 engine questions
Hi everyone,
I made my initial post on the general thread but was recommended to post on the M6 thread.
I bought an M6 GC through insurance. Left Front hit and stationary. I was well aware it was going to be a 50/50 toss up getting the thing to run but for the spec and final price it was worth a shot. It has been neat to learn about, my limited engine experience has made the s63 car a rude wake up call with the circuits and computers.
Anyhow, I got to the point of test starting the car and unfortunately I believe the engine is blown. The radiators still leaked after filling up with coolant although I don't think it should've prevented a test start.
Question: Will the circuits sensing the coolant levels prevent the engine from turning even if the starter engages?
I'll attach a video of what I heard, I've been second guessing myself but it sure sounds like the starter to me. I ask because the coolant was absolutely not completely full and hard to know whether the coolant was truly circulating or not. I'm assuming the starter engaging but no crank means seized engine
Thanks Everyone!
Test Start Vid: https://drive.google.com/file/d/1NYm...ew?usp=sharing
      03-02-2021, 03:01 AM   #2
MARKPRIOR
156
Drives: 2017 M6 GC
well that doesnt sound right....
it certainly sounds like its spining to fast for the starter to be engaging / turning the crank / flywheel
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5,
Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff
      03-02-2021, 05:03 AM   #3
NGROSSO
To me, that would be fantastic news. Could it potentially be a burnt out starter?
      03-02-2021, 08:14 AM   #4
MARKPRIOR
156
Drives: 2017 M6 GC
could be, have you had any diagnostic software on it ? bimmerlink or something better like snapon, you will get some codes to start you off i guess
      03-02-2021, 08:54 AM   #5
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
I do not know the part number for our Gran Coupe's but a previous M6 with the S85 that I owned had a link off the battery that would disable power to the ignition. It is a safety measure to prevent the car from starting but does not kill the power to accessories. It will be on the positive side of the battery. That would be the first thing I would check.
      03-02-2021, 09:55 AM   #6
patchesj
patchesj's Avatar
68
Drives: BMW M6
Are the belts turning on the front of the engine? that will tell you if the starter is engaged or not. Any of the safety circuits would likely prevent the starter from even turning.
      03-02-2021, 03:28 PM   #7
NGROSSO
I am going to use bimmerlink to see what I can find. Thank you for the recommendation.
      03-02-2021, 03:33 PM   #8
NGROSSO
Since the starter seems to function of some sort I assumed that meant ignition had power but it is certainly worth investigating. Thanks.
      03-02-2021, 06:08 PM   #9
NGROSSO
The belts were not turning which made me suspect a seized engine because on initial Impressions I was almost certain the noise made after hitting the ignition was the starter engaging.
      03-03-2021, 02:20 AM   #10
MARKPRIOR
156
Drives: 2017 M6 GC
easy way to check this would be to put a large torque bar on the bottom pulley and attempt to crank by hand, if its siezed you would get no movement. i would expect lumpy resistance when turning due to compression, thats normal.
i would suspect this is starter or something other than a siezed engine
      03-03-2021, 10:41 AM   #11
Spacecpe
Drives: E90 335i Msport
Doesn't even sound like it's cranking.. if the engine was locked up, the starter would just click (doesn't sound like the engine doesn't have compression either). This sounds like the starter isn't even connected to the flywheel. Sounds like a regular electric motor spinning on its own If that makes sense.
      03-03-2021, 10:41 AM   #12
NGROSSO
Thanks for your continued help, this is much appreciated. I'm probably missing something obvious, but when looking to get down to the bottom pulley it seemed way to tight between the radiators, fans and hoses to actually reach it and get a bar in there.
Is the only option removing parts like the radiator brace and fan to reach it?
      03-03-2021, 10:44 AM   #13
NGROSSO
Makes perfect sense and that is the way I'm starting to lean as well. The starter is definitely connected to the fly wheel but I'm questioning whether its a burnt out starter or if there is a misconnection somewhere else. Im hoping the OBDII scan I'm waiting on will be able to tell me something on that. Thank you.
      03-03-2021, 10:46 AM   #14
Spacecpe
No problem. Maybe try to take it out and see if the teeth are fine. But definitely sounds like a starter issue
      03-04-2021, 04:40 AM   #15
MARKPRIOR
156
Drives: 2017 M6 GC
you could try from underneath, my cars in the dealer so cant check how easy that is
      03-04-2021, 11:52 AM   #16
NGROSSO
Decided to remove front end since I will have to replace a couple radiators anyways. Thanks for the tips.
      03-05-2021, 07:49 AM   #17
MARKPRIOR
156
Drives: 2017 M6 GC
let us know how you get on, seriously doubt the engine is siezed / damaged
      03-05-2021, 02:16 PM   #18
NGROSSO
Attempted hand turning today and no cigar. I haven't barred an engine before and wasn't sure how much resistance I should feel considering compression although it didn't seem right.. Mechanic coming on Monday to look for himself and hopefully find a different answer.
In the mean time anyone know of certain codes that might tell me something relating to a bad engine? Oil level is good...
It's been neat playing with bimmerlink and seeing all the info.
      03-05-2021, 02:48 PM   #19
TinCanSailor
630
Drives: F06 M6
It could be due to the car being in "Park"/Gear. Were you able to get it in neutral?
      03-05-2021, 03:23 PM   #20
NGROSSO
I haven't been able to get it into neutral because it requires the car being started although from what I've read online it seems an automatic should be fine to hand turn while in park. Let me know if this sounds incorrect
      03-05-2021, 04:03 PM   #21
patchesj
patchesj's Avatar
68
Drives: BMW M6
Uh, if it is a DCT it isn't an automatic... The clutch will be engaged when in "P", it is actually in gear. There is a procedure for forcing to Neutral with engine off.
      03-05-2021, 04:56 PM   #22
NGROSSO
Noob error on my part. Thanks for the tip. I do remember seeing something about forcing neutral with the DCT although it sounded like you needed to get under the car to do it and remove a bolt from the trans. I'll investigate
Edit: Theres a screw that needs to be screwed in to push a lever forcing the car into neutral. Thanks for the help
