      01-21-2011, 11:16 PM   #1
Nachos23
HotBimmer
Nachos23's Avatar
Drives: 2016 335GT & 2000 Z3M Roadster
2016 BMW 335GT  [0.00]
2000 BMW Z3M  [0.00]
Talking Evo rear spoiler restoration project
Hey;
Was given a Evo rear spoiler with the factory clear coat peeling, chipping and badly yellowed. Apparently, this is a known issue with this model. Really bad shape!! Unfortunately, I never took a picture before I started it (thought I had, but apparently not).
Here's the project pictures from about 1/3 way through initial sanding through to finished spoiler:
Now Ready for Clear Coat:
Just like new (actually in this case; better cause this won't yellow, chip or peel) :thumbup:
      01-21-2011, 11:34 PM   #2
MontegoblueE92
MontegoblueE92's Avatar
76
Drives: It Like He Stole It
Wow that looks incredible. Good job!
      01-21-2011, 11:44 PM   #3
Nachos23
HotBimmer
Nachos23's Avatar
2000 BMW Z3M  [0.00]
Thanks, about 6 hours of wet sanding to get it done!!!
      01-21-2011, 11:51 PM   #4
flipmeraz
flipmeraz's Avatar
209
Drives: 10 e92 m3
That turned out really good. Can you post the materials you used? TIA
      01-21-2011, 11:53 PM   #5
Nutballa
Nutballa's Avatar
Drives: BMW F13 M6 // BMW F22 M235i
Steps and how to, please? Materials?
BMW FTW!
"Power is nothing without Control" - Pirelli.
      01-22-2011, 12:06 AM   #6
Nachos23
HotBimmer
Nachos23's Avatar
2000 BMW Z3M  [0.00]
NO real tricks here.
1. Wet sanded starting with 220, then 400, 800 + 1000. Kept washing and drying regularly to ensure I wasn't cutting too close. 90% of sanding done with 220 grit. About 3 sheets of 220 required. about 2 sheets of each of the other grits.
2. Clear coat. Used BASF DC92 base, DH42 rapid hardener and UR50 reducer (20% for first coat and 30% for second coat; thinner + smoother, but more prone to runs; so have to be real careful).
That's it!! Just about 6 hours total of wet sanding. No power tools even though I have orbital sanders, polishers, etc..... didn't want to chance cutting through cloth.....
      01-23-2011, 07:46 PM   #7
Nachos23
HotBimmer
Nachos23's Avatar
2000 BMW Z3M  [0.00]
      01-23-2011, 08:18 PM   #8
ben14142001
Drives: 2018 M3 ZCP
Beautiful.
      01-23-2011, 08:36 PM   #9
Nachos23
HotBimmer
Nachos23's Avatar
2000 BMW Z3M  [0.00]
Actually quite proud of it..... as I said previously, I was real concerned about damaging carbon fiber base as the clear was sooooo badly damaged...
      01-23-2011, 09:08 PM   #10
hks786
2169
Drives: *
Very good work. Painting isn't impossible and when you get the hang of it and remember a few rules you'll be able to keep doing good. Got any pics of your car?
      01-23-2011, 09:27 PM   #11
Nachos23
HotBimmer
Nachos23's Avatar
2000 BMW Z3M  [0.00]
Setting the gun is the biggest challenge now! Have a decent compressor running it.... 60 gallon, 18.5 cfm @ 100psi; Tsunami 3-stage filtration and a DeVilbiss GFG-670 Cup feed. One drawback is I'm running 1/4" pipes.... Need to install the 1/2" manifold and 5/8 high flow fittings. I've had the parts for the manifold on the floor for the last 4 months; been crazy..... Takes a while to setup gun each time... Have test pieces I spray to check flow, etc before spraying anything to be finished.....
Here's a couple of pics of my car:
The rubber @ top pf lip was just until I properly fitted it.... Notice it's gone in the above picture......
After installation of a DCT shifter and transferring all functions, I needed custom manual shift boot. Going to be cutting down about 1" or more soon!!
Engine Bay Pictures:
Those engine covers now are almost done and look like this....
      01-24-2011, 10:14 PM   #12
Addicted2Boost
FBO
Drives: JB E92 335i
good job!
      01-25-2011, 08:23 AM   #13
Nachos23
HotBimmer
Nachos23's Avatar
2000 BMW Z3M  [0.00]
Thanks. That's a SICK ride dude!!
      01-25-2011, 09:03 AM   #14
Garduna
Garduna's Avatar
Drives: Sedona 1er|Yellow S3|NardoTTRS
awesome restoration on the spoiler!!!
      01-25-2011, 09:14 AM   #15
Nachos23
HotBimmer
Nachos23's Avatar
2000 BMW Z3M  [0.00]
Thanks! Took alot of time to hand sand to this finish.
Tags
carbon, clear coat, evo, restoration, spoiler
