      04-12-2016, 07:41 PM   #1
dubthis
Drives: X5 MSport, E36 S54
M6 Boost Gauge P3 Cars Integrated Vent
BIMMERPOST / Classifieds
Asking Price:
USD 350.00
✓ Will Ship
Item Interest
P3 Cars Integrated VIDI Vent Gauge for 2011-UP BMW F12 F13 6-Series Model
New in original box. MSRP $509.00
Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
Specifically designed to support the F12 6 Series platform.
*Quick plug and play install with zero cutting required. All power and ground connections come directly from the low profile concealed diagnostics port connector.
*High resolution boost/vacuum sensor and display showing actual manifold boost, Can also read Boost/Vaccum via diag port on n55 engine cars.
*Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more
*Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
*Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
*Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
      04-17-2016, 10:53 AM   #2
dubthis
SOLD!
