02-21-2021, 03:43 PM | #1 |
Rep 36
Turbo coolant lines?
Had to refill my coolant last night and after further research, people said to check the coolant box that is located underneath the motor cover (the one you just pop off) i waited for my car to cool down and the "coolant low message" went away along with the limp mode. As I went to go back to check the other coolant box that's underneath the motor cover and found these corroded lines. I believe these are the turbo coolant lines that's connected to the front coolant box. Opened the front coolant box and the fluid was holding steady at the "max" amount. I'm curious if these corroded lines are something to worry about?
Facts about the case: Only refilled coolant at the top driver side location Only checked to see if the bottom coolant needed coolant and didn't. No further error messages pop up after refilling coolant. |
02-21-2021, 06:04 PM | #2 |
Rep 2,901
Just FYI, the system that uses that front little reservoir is totally separate, and has no level sensor or warning. It does not connect to the turbo lines. That front system does not get very hot, and cools the charge air coolers - those two silver boxes up front - and your two engine computers. As for the "corrosion", I'm not sure exactly what that is. It looks like a sealant of some type. I would clean that off, then monitor it to see if anything returns.
02-21-2021, 07:42 PM | #3 |
Rep 1,819
Those are the turbo coolant lines and yes they will need to be looked at. BMW dealers routinely replace those (mine were done a year ago). You will likely see coolant residue if you look behind the alternator as well.
02-21-2021, 09:34 PM | #4 |
Kraut Driver
59
Rep 624
These three things and you can DIY it better than a dealer replacement (hose clamp kit was kinda shit. They won't cut through the old clamps so have good cutters for those.)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
Walt White Coupe220.50 |
02-21-2021, 10:21 PM | #5 | |
Rep 36
02-21-2021, 10:23 PM | #6 | |
Rep 36
02-22-2021, 09:21 AM | #7 |
Rep 7,449
Here's some info about the N63TU's cooling system circuits (yes multiple circuits as mentioned above).
Hopefully the info below will be helpful with understanding the complexity of the 3 cooling circuits found on the N63TU engine (which is slightly different than the original N63 engine's systems).
02-23-2021, 11:51 PM | #8 | ||
Rep 103
Drives: 550i 2014
07-11-2021, 10:38 PM | #9 | |
Rep 79
thank you |
07-12-2021, 07:30 AM | #10 |
Rep 2,901
07-24-2021, 03:38 PM | #12 | |
Rep 289
