06-09-2021, 09:04 PM | #23 |
Rep 9,160
Haldex awd, so likely 100% fwd until slip is detected with a max of 50% to the rear under slip. Hence his comment about being fwd based.
06-10-2021, 09:57 AM | #24 |
Rep 384
Ford uses their own FWD-based AWD but it works similar to Haldex. On my wife's Explorer Sport is stays in AWD under 30mph, then switches to slip&grip FWD above that. Supposedly it can send 100% of torque to the rear wheels if needed but might just be Ford marketing BS.
06-10-2021, 11:52 AM | #25 | |
Rep 9,160
But yeah, frequent Haldex marketing fluff says 100% to the rear, but they really just mean 100% of the available 50%. The Bronco Sport apparently has the old Focus RS setup which does have the ability overdrive the differential for short periods and can send about 60% to the back. |
06-10-2021, 12:38 PM | #26 |
Rep 562
06-10-2021, 01:44 PM | #27 |
Rep 2,291
This is exactly what I need. I don't need a truck, but would like one to go to Home Depot in to haul stuff for the garden or projects around the house.
I'm hoping when it is released and hopefully the chip shortage will subside eventually so that more dealerships have them. In that case, hoping leasing becomes super cheap so I can simply add this to the stable and use it when I actually need it.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
06-10-2021, 01:56 PM | #28 |
Rep 819
I have no need for a pickup, but it's always nice to have another option. That said, if they were going to recycle a name they should have used Courier instead.
This post sent using 100% recycled electrons.
06-12-2021, 07:08 AM | #29 | |
Rep 18,733
06-13-2021, 01:10 PM | #30 |
Rep 6,926
06-13-2021, 01:18 PM | #31 |
Rep 6,926
Just realized this thing is hybrid as standard. Estimated 40mpg city and 500 miles per tank. Excellent value for money. They should sell plenty of these.
IllSic_Design2124.00 |
