      02-21-2021, 03:43 PM   #1
daniel650i
daniel650i's Avatar
Drives: bmw 650i gc
Turbo coolant lines?
Had to refill my coolant last night and after further research, people said to check the coolant box that is located underneath the motor cover (the one you just pop off) i waited for my car to cool down and the "coolant low message" went away along with the limp mode. As I went to go back to check the other coolant box that's underneath the motor cover and found these corroded lines. I believe these are the turbo coolant lines that's connected to the front coolant box. Opened the front coolant box and the fluid was holding steady at the "max" amount. I'm curious if these corroded lines are something to worry about?
Facts about the case:
Only refilled coolant at the top driver side location
Only checked to see if the bottom coolant needed coolant and didn't.
No further error messages pop up after refilling coolant.
      02-21-2021, 06:04 PM   #2
Opie55
Drives: '15 650i Convertible
Just FYI, the system that uses that front little reservoir is totally separate, and has no level sensor or warning. It does not connect to the turbo lines. That front system does not get very hot, and cools the charge air coolers - those two silver boxes up front - and your two engine computers. As for the "corrosion", I'm not sure exactly what that is. It looks like a sealant of some type. I would clean that off, then monitor it to see if anything returns.
      02-21-2021, 07:42 PM   #3
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
Those are the turbo coolant lines and yes they will need to be looked at. BMW dealers routinely replace those (mine were done a year ago). You will likely see coolant residue if you look behind the alternator as well.
      02-21-2021, 09:34 PM   #4
DRock3d
Kraut Driver
DRock3d's Avatar
Drives: 2014 650i GC/2011 335is DCT
2014 650i Gran Coupe  [0.00]
2011 335is  [1.00]
2007 328i  [2.00]
These three things and you can DIY it better than a dealer replacement (hose clamp kit was kinda shit. They won't cut through the old clamps so have good cutters for those.)
      02-21-2021, 10:21 PM   #5
daniel650i
daniel650i's Avatar
Drives: bmw 650i gc
Thank you for your help
      02-21-2021, 10:23 PM   #6
daniel650i
daniel650i's Avatar
Drives: bmw 650i gc
https://www.amazon.com/gp/product/B0...UTF8&psc=1
Thank you
      02-22-2021, 09:21 AM   #7
Here's some info about the N63TU's cooling system circuits (yes multiple circuits as mentioned above).
Hopefully the info below will be helpful with understanding the complexity of the 3 cooling circuits found on the N63TU engine (which is slightly different than the original N63 engine's systems).
  1. Engine Cooling Circuit
  2. Turbo Charging Circuit
  3. Charge Air & DME Cooling Circuit
      02-23-2021, 11:51 PM   #8
550ihtown
Drives: 550i 2014
2008 M3 E93  [0.00]
2022 BMW X7 M50i  [0.00]
I had the exact same problem on my 550i which has a similar model. If you trace the rubber lines, they go up to a metallic part which also is replaced most of the times by dealerships - which can be an unnecessary additional cost. So you should ask them to just do the rubber ones and you will be ok. I drove my car for another 20k miles after that and I had no issues again. It was a $600 repair in comparison to $2500 for getting the whole metallic pipes changed along with.
      07-11-2021, 10:38 PM   #9
Oris4
Drives: 2012 BMW X5 35i
DRock can you repost the links, all three links result in amazon error page and unfortunately I am having this issue.
thank you
      07-12-2021, 07:30 AM   #10
Opie55
thank you
Links worked for me just now. I think it was an Amazon issue last night.
      07-12-2021, 11:17 AM   #11
Oris4
you are correct, links working now. thank you
      07-24-2021, 03:38 PM   #12
itzjoker
itzjoker's Avatar
150
Used these and they work fine. The hose is much thinner compared to OEM, so careful touching them when engine is warmed up. The brass T is a bit small for the bottom hoses that go towards the radiator but hopefully the crimp clamps will hold it. I didnt change the hose that fits into the bottom T since the 3/8" hose above seemed too small.
