02-12-2022, 12:38 PM | #1 |
Rep 653
Drives: 2022 G20 M340i
Garage List 2021 BMW X5 [0.00]
1991 Ford Mustang GT [0.00] 1993 Ford SVT Light ... [0.00] 2020 Harley-Davidso ... [0.00] 2013 Porsche Boxster [0.00] 2018 BMW 340i M-Spo ... [10.00] |
Tire Size M240 vs M340
I'm curious why the 22- M240ix comes with 245/35/19 tires when spec'ed with performance wheel/tire option but the M340i when ordered with the same option only comes with 225/40/19 tires? Is this to artificially make the "small" coupe handle better than the "family sedan"?
Chuck
2022 G20 M340i PB/Oyster Last- 2018 F30 340i 6MT ZHP AW/CRed |
02-12-2022, 06:44 PM | #2 |
Rep 7,093
Drives: 2018 M2 AW DCT
Overall the tire sizes are very comparable. The 225/40/19 does have a 4 mm side height increase which should give it a little softer ride.
https://tire-calc.com/comparison/225...nd-245-35-r19/ |
02-14-2022, 10:49 PM | #3 |
Rep 3,605
225s on a sports sedan of that size is obvious corner-cutting, most likely for cost to keep overall price down. A car that heavy with that intent shouldn't have 225s. 255 would be more fitting. The problem is the wheels themselves would need to be wider, you don't want a wider tire stretching over a skinnier wheel, that creates bead roll-over and decreases sidewall stiffness for cornering, etc. The heavier the car, the more this is an issue. The manufacturers realize that 95% of people care about wheel diameter only, so they make flashy large diameter wheels and basically "who cares?" about the width and actual performance.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
02-15-2022, 12:08 AM | #4 | |
Rep 2,581
This looks like a new add to take advantage of the front end grip in the chassis. |
