01-13-2022, 05:33 AM | #1 |
Rep 61
My 2012 650i convertible (F12) is stored during the winter season and the negative terminal is disconnected from the main battery to prevemt drain. Is it advisable to also disconnect the negative terminal from the auxiliary battery?
2007 BMW X3 2.0i E83
2012 BMW 650i Convertible F12 2023 BMW X3 Xdrive 30e G01 Gone: 2002 BMW 330i Convertible E46 2020 BMW X3 Xdrive 30e G01 |
01-13-2022, 10:30 AM | #3 |
Rep 7,361
If you have an aux battery, then yes...disconnect it as well. Aux batteries were used with certain combinations of engine and gearbox (weight on the front axle), like a more powerful electromechanical power steering system fitted for the option (SA2VH) "Integral Active Steering". The electromechanical power steering can be operated with 24 Volts.
The car is still powered when you have multiple batteries & one of the batteries cables is removed. If you have dual batteries...the aux battery is G6 in the illustration below. Not all f06/f12/f13 six series have aux batteries:
01-13-2022, 09:06 PM | #4 |
Rep 279
I drive my current 650 convertible with xDrive year round - main reason for getting the xDrive. I had a 2004 645 that I stored in the winter with a battery tender. However, be careful who you store it with. I had two dead batteries in the 4 years I stored with them!
01-14-2022, 04:42 PM | #5 |
Rep 627
I think the aux battery is required for all electric "power" steering cars (as a safety item). Mercedes Benz also uses an aux battery in the cars with electric power steering.
F06 M6 Grand Coupe CP
01-15-2022, 12:12 AM | #6 |
Rep 61
Makes sense as I have the active steering option.
