      01-13-2020, 04:14 PM   #23
General Lee
General Lee's Avatar
75
Drives: M6 GC
2015 M6 GC F06  [0.00]
Originally Posted by Havy View Post
I have the same message after washing the car. Additionally I got the message that the parking brake is not functional. Could it be a low voltage battery?
I thought of disconnecting the battery for about 10 min. And see if the message comes back.
Does all the memories stay or do I have to set them again.
I still get the message but I’ve left it for 3 weeks and never a problem starting it. My dealer gave up trying to locate the cause. Another non Bmw dealer that retrofitted my reversing camera said the drain is probably minute and he’s found the system can be far too sensitive so I’m living with it ...
      01-16-2020, 07:25 AM   #24
Taheemr
280
Drives: M6 GC
Sytner have had several attempts at fixing my battery drain issue, so far they have
- replaced battery
- New starter motor
- New CAS unit
Issue still there, not sure whats next
      01-16-2020, 09:41 AM   #25
RagtagXMASTER
RagtagXMASTER's Avatar
119
Drives: 2013 M6
Sometimes its door handles from soft close/comfort access. you definitely have an issue, i doubt it would be the ZGW gateway module but you never know. start pulling fuses and see which one causes the draw. you can setup a multi meter in series with your battery, and as you pull fuses it will at least show which circuits are drawing.
      01-16-2020, 10:27 PM   #26
M6ORL
M6ORL's Avatar
Drives: Bmw m6 bmw 530i
Originally Posted by General Lee View Post
Does anyone get this message pop up? Ive made sure my battery is fully charged with a top of the range trickle charger (all 5 lights so OK) - is this standard or does it suggest my battery is draining?
that happens to me like a year ago the car gave me that msg i re-rharge the battery and like a month after omw to tampa i floor it a little on the highway the car went into limp mode (drivetrain malfuction msg ) i panic and drove straight to the dealer, 500.00 something dollars later a new battery ... * , long story short if your battery is old 4 or 5 years replace that b##$* and save yourself a couple of hundreds and the stress of having that warning on your i drive...
      01-22-2020, 02:59 PM   #27
elvisisdog
Drives: F06 MSport 2013/09
Great post, getting the same message although right hand drive 640d F06. My problems started after taking the washer bottle out to clean filters that were all gunked up. In taking the bottle out I had 2 wires that ran under the door sill to what I assume is the antenna to the comfort access. The wire was tight and didn't want to move out of the way easily. Since doing the work I've started getting comfort access problems in the drivers door. Initially thought it was key fob and replaced that little battery. Still got the problem and intermittent comfort access from the boot (trunk) to the drivers side. Now I get the battery drain warning above along with reduced function of folding mirrors and steering wheel tilt. My cars done 95k miles and I still use start stop on daily basis, cars about 6 years old now so I wouldn't be surprised if it needs a new battery anyway. I vaguely remember that some of the cars have two batteries, anyone know what the 640D had in the F06?
Also does anyone have a reference or link on how to check the cabling to the comfort access antenna? My worry is I've damaged the cable and trying to identify if it is just signal and positive or positive and negative or something entirely different. Any idea if I can check the wiring to the antenna with just a multi meter or if it needs something a bit more special.
      02-15-2020, 03:16 PM   #28
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
Yep, I think now it’s time to change my battery as well. I use a battery charger/ tender but a 6 year old is at it’s end I guess.
