06-22-2021, 01:21 PM | #1 |
Rep 381
NBT Evo and trunk mess
Hi there!
Does anyone have an experience with retrofitting NBT Evo in 6er 2013-2015? What does it cost and what parts did you use? Another question, no hooks or holders in the trunk. Do you use any aftermarket? All my stuff in the trunk goes back and force during riding. |
06-30-2021, 03:38 PM | #4 | |
Rep 1,822
In short, if you have CIC installed you will need HU, Display, Audi Amp, Antenna Amp, controller, handwriting module (if you want it) and retrofit module to convert the can signals (unless you do what I did and re-wire the car and update the ZGW) If you have NBT you will need HU, display converter cable (unless you want to replace the display) and a retrofit module (or rewire as above). If you are doing this purely to get Carplay then you'd be much better off just getting an interface box. It's cheaper, easier to install and less destructive.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
06-30-2021, 04:51 PM | #5 | |
Rep 7,462
06-30-2021, 04:57 PM | #6 |
Rep 628
Clip #7 which holds the rear net #6 is not very robust. After breaking and replacing two of them, I just drilled two small holes either side of the loop and ran a small zip-tie around the frame of the net. Have not had a failure since.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination Last edited by arucano; 07-02-2021 at 05:25 PM.. |
06-30-2021, 05:13 PM | #7 | |
Rep 7,462
I also forgot to mention that there’s also a larger trunk net that is available…you can get the part number from the database and order online or order it from your local BMW dealership’s parts department:
07-02-2021, 10:14 AM | #9 |
Rep 251
07-02-2021, 12:34 PM | #11 | |
Rep 7,462
Click link above and scroll down to item #7 in the part number index below the diagram. Once you have the 11 digit BMW part number…you can search for it on line (ie type BMW xx xx x xxx xxx into a google/internet search box)…or you can ask your local BMW dealership to lookup the part number. They may have it in stock or may have to order it…either way, you can always ask them if they price match if it is cheaper on line. Even if they cost a little more…you may still be able to save some $$ if it will cost less paying their price + local taxes versus the lower cost + shipping & handling by purchasing online. Good luck.
MNhv92.00 |
07-21-2021, 03:13 AM | #12 |
Rep 13
I installed complete system B&o in my BMW F06 and I am not at all happy with the sound. HK Top HiFi was better I think. Though Movies sound great but music did not like at all.
