      05-26-2021, 11:22 PM   #1
Illmatic127
Drives: BMW F06 M6
201101 DME: Protection against tampering code, will it pass smog?
Hello - I recently tuned the car back to stock using AutoLogic for the sake of passing smog check, but now seeing this error:
201101 DME: Protection against tampering: Program or data manipulation detected
Does anyone know if this will impact ability to pass smog? any help is greatly appreciate it!
      05-28-2021, 10:10 PM   #2
Whipple
Whipple's Avatar
263
If you dont have a check engine light on you will pass smog
      06-01-2021, 03:15 PM   #3
Illmatic127
Drives: BMW F06 M6
Ok, thanks for the input. Crossing my fingers it'd pass!
      06-02-2021, 03:34 PM   #4
schnell1982
Drives: FAST
That is only a result of performance engine software coding.
It does not affect the OBD readiness status
As long as you have your readiness monitors "Ready" you will be good to go.
