      06-22-2021, 01:21 PM   #1
Kolianovskyi
Drives: BMW 650i
NBT Evo and trunk mess
Hi there!
Does anyone have an experience with retrofitting NBT Evo in 6er 2013-2015? What does it cost and what parts did you use?
Another question, no hooks or holders in the trunk. Do you use any aftermarket? All my stuff in the trunk goes back and force during riding.
      06-22-2021, 10:33 PM   #2
Kolianovskyi
Drives: BMW 650i
Parampampam.
      06-29-2021, 07:38 PM   #3
Kolianovskyi
Drives: BMW 650i
Another upgrade in the trunk. 😂
      06-30-2021, 03:38 PM   #4
hugo_nz
hugo_nz's Avatar
3185
2022 BMW IX  [0.00]
Originally Posted by Kolianovskyi View Post
Hi there!
Evo retrofits have been covered extensively in several threads, so I'd start with a search.
In short, if you have CIC installed you will need HU, Display, Audi Amp, Antenna Amp, controller, handwriting module (if you want it) and retrofit module to convert the can signals (unless you do what I did and re-wire the car and update the ZGW)
If you have NBT you will need HU, display converter cable (unless you want to replace the display) and a retrofit module (or rewire as above).
If you are doing this purely to get Carplay then you'd be much better off just getting an interface box. It's cheaper, easier to install and less destructive.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic
      06-30-2021, 04:51 PM   #5
There are two “lashing eyes” on each side of the trunk (#13/#14 in the 1st diagram below) which you can attach bungee cords to…and the luggage compartment net (#6 in the 2nd diagram below) which I think has metal clips/holders on each side of #5 that you may be able to attach a bungee cord to and possibly attach to one of the lashing eyes. Also take a look upward to the area below the rear parcel shelf. Check there to see if there are openings or something you can latch onto or thread a bungee cord through…which again may allow you to facilitate securing items with the lashing eyes and the “net” at the rear of the trunk.
      06-30-2021, 04:57 PM   #6
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
Clip #7 which holds the rear net #6 is not very robust. After breaking and replacing two of them, I just drilled two small holes either side of the loop and ran a small zip-tie around the frame of the net. Have not had a failure since.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      06-30-2021, 05:13 PM   #7
Originally Posted by arucano View Post
Clip #5 which holds the rear net #6 is not very robust. After breaking and replacing two of them, I just drilled two small holes either side of the loop and ran a small zip-tie around the frame of the net. Have not had a failure since.
good input to actual experience.
I also forgot to mention that there’s also a larger trunk net that is available…you can get the part number from the database and order online or order it from your local BMW dealership’s parts department:
      06-30-2021, 05:51 PM   #8
Kolianovskyi
Drives: BMW 650i
That net is so strange solution. If you put something you do not have flat floor any more))) I would prefer to have my bags stand with hooks.
      07-02-2021, 10:14 AM   #9
MNhv
MNhv's Avatar
Drives: F85 X5M
[/center]
Can you please share the part number/link for the #7 clip? Mine broke and I've been trying to find a replacement. Thanks!
      07-02-2021, 12:22 PM   #10
Kolianovskyi
Drives: BMW 650i
Another storage)))
      07-02-2021, 12:34 PM   #11
Here’s a direct link to the bimmercat part database. You had no vehicle model year listed…so I generically selected an LCI M6: https://bimmercat.com/bmw/en/search/...M6/USA/51_8185
Click link above and scroll down to item #7 in the part number index below the diagram. Once you have the 11 digit BMW part number…you can search for it on line (ie type BMW xx xx x xxx xxx into a google/internet search box)…or you can ask your local BMW dealership to lookup the part number. They may have it in stock or may have to order it…either way, you can always ask them if they price match if it is cheaper on line. Even if they cost a little more…you may still be able to save some $$ if it will cost less paying their price + local taxes versus the lower cost + shipping & handling by purchasing online.
Good luck.
MNhv92.00
      07-21-2021, 03:13 AM   #12
manyaksh
Drives: BMW F06
I installed complete system B&o in my BMW F06 and I am not at all happy with the sound. HK Top HiFi was better I think. Though Movies sound great but music did not like at all.
      07-21-2021, 03:17 AM   #13
manyaksh
Drives: BMW F06
Installed evo id 6, B&O, HUD, 6WB Instrument cluster and also will be doing the LCI Headlights already bought.
