11-05-2021, 04:47 AM | #1 |
Rep 2
Symptoms of catalytic converter failure
Hi,
Anyone here kindly advises about the symptoms of a catalytic converter failure. If it is indeed faulty can it cleaned or it needs straight replacement. Thank you in advance. |
11-05-2021, 10:02 AM | #2 |
![]() ![]() ![]() 8891
Rep 6,722
Drives: 2018 M2 AW DCT
Here is a link for you: https://palmbeachgarage.com/catalytic-converter/
I believe BMW is required to warranty catalytic concverters for 8 years or 80,000 miles. |
11-05-2021, 10:24 AM | #3 |
![]() 769
Rep 1,417
Drive it hard! That is the best way to "clean" it. If you get any stuttering or misfires and you can't get it cleared out, you might need to replace it.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
11-05-2021, 03:09 PM | #5 |
Cole
![]() 317
Rep 498
Bmw just replaced both of my cats under warranty. Im at just under 60k miles.
Only issue i ever saw was a repeated intermittent cel for catalyst inefficiency. The procedure for inspecting the cats before replacement per BMW is to pressurize the exhaust system, test for leaks, followed by unbolting from the turbos and visually inspecting. |
11-17-2021, 04:54 PM | #6 |
Rep 6
the car should throw a fault code if the catalytic converters are below efficiency. if they are clogged it will give you performance issues under load. these are replacement pieces, no way to clean or repair them.
11-17-2021, 11:08 PM | #7 |
![]() ![]() ![]() ![]() 548
Rep 650
Lol, in addition to the above, after a nice drive, take a look under the car, the converter will be a different color usually when failing as it is usually blocked...
