      01-18-2021, 04:17 PM   #1
DinishK
Drives: 13' F13 M6
Tire setup advice
Hey guys,
Looking for some advice on what size tires I should get for my F13 M6.
I want to have most aggressive setup for my wheels.
Wheels: Rohana RFX5
F: 20x10 ET +25
R: 20x11 ET +35
KW HAS Suspension.
Thank you !
      01-18-2021, 06:28 PM   #2
DinishK
Drives: 13' F13 M6
Anyone??
      01-18-2021, 07:30 PM   #3
FinalRenegade
FinalRenegade's Avatar
Drives: M6 GranCoupe | Last Model Year
First,
use this to see how the new rims will change your stance ; for example will the offsets work etc and how much compared to stock are your rims poking out/caving in, then you can use the second link to calculate max tire size
1) https://www.willtheyfit.com/index.ph...9-5&offset2=20
2) https://www.wheel-size.com/calc/
Hopefully you can find a set up which fits without having any rubbing issues
HeyKC101.50
      01-19-2021, 12:28 PM   #4
HeyKC
Drives: BMW M6 CP
Originally Posted by DinishK View Post
Hey guys,
Wheels: Rohana RFX5
F: 20x10 ET +25
R: 20x11 ET +35
KW HAS Suspension.
Thank you !
http://www.rimsntires.com/specspro.jsp
I don't know enough to understand how much you can push it but, when I start looking for new rears I think I am going to go with PS4S in 315s.
      01-19-2021, 12:32 PM   #5
brad850csi
Drives: 16 F13 M6 Comp
The stock wheel offset is 19mm so you'll need ~15-20mm spacers at the rear for a start.
I'd go 275/35r20 and 305/30r20 or 315/30r20
