      09-30-2018, 12:47 PM   #1
650GC
2013 BMW 650i Gran Coupe M package
I'm currently running the following specs:
Rohana RF2 Matt black
Front 20x9 ET35 with 255/35/20 Michelin pilot super sports
Rear 20x11 ET40 with 295/30/20 Michelin pilot super sports
I'm really happy with the above setup, the stock runflats and wheels were super heavy compare to Rohana RF2s.
I weighted both wheels as attached.
Stock Bmw 373 style weight as follow:
Front 20x8.5 ET33 with 245/35/20 Dunlop SP sports maxx GT
-Rim+tire weight 33+31=64LB
Rear 20x9 ET44 with 275/30/20 Dunlop SP sports maxx GT
-Rim+tire weight 33+34=67LB
-Flat face, no concave
-Rim+tire weight 24+25=49LB
-Medium concave, looks alot better and deeper in person. Pictures don't show much of the concave.
-Rim+tire weight 25+29=54LB
**NO RUBBING ISSUES AT ALL**
Sorry for blurry pictures, they were taken with my cell phone in dark but many of you will get your answers your looking for.
The photos are a little off from the above mentioned weights due to used tires and weight installed on rims after balancing.
      09-30-2018, 12:54 PM   #2
Genovese45
Drives: 2020 M850 Gran Coupe
nice.
650GC14.50
      09-30-2018, 02:11 PM   #3
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
Looks awesome
650GC14.50
      09-30-2018, 02:25 PM   #4
FBMWWINS
FBMWWINS's Avatar
604
Cool one for sure and good to know.
650GC14.50
      09-30-2018, 11:46 PM   #5
Chili Palmer
Master Of My Domain
Drives: 2015 650i Gran Coupe
Looking good! I love the way 295's tucked under the rear fenders look.
You're right stock 373's are freaking heavy, the M5 wheels I swapped out with wider tires still weigh considerably less than factory wheels and tires.
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
650GC14.50
      10-01-2018, 02:52 AM   #6
FBMWWINS
FBMWWINS's Avatar
604
For the M5 wheels (M343) did you have to modify anything? The main difference is really on REAR where:
M373:
9x20 - 275/30R20 ET 44
M343
10x20 - 295/30R20 ET 34
Thus 10J instead of 9 and ET 34 over the original ET 44.
      10-01-2018, 05:22 AM   #7
Chili Palmer
Master Of My Domain
M373:
M343
[COLOR="Red"]10x20 - 295/30R20 ET 34[/COLOR]
No, they fit fine, the rims stick out slightly past the fender edge, but I'm running 285/30 tires in the rear and it's barely noticeable, but if I ran 295's they'd stick out past the edge of the fender. Probably with an ET of 40 I'd be able to stuff the 295's without any issue. But they aren't so I can't.
650GC14.50
      10-01-2018, 06:51 AM   #8
FBMWWINS
FBMWWINS's Avatar
604
Indeed you have it looking very decent and better than stock!
After reviewing on a wheel-size.com and comparing OEM with the M343 with 295 tires it reads as follows:
"Tire will stick out 20 mm farther. Rim will stick out 23 mm farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset"
Though the above hint is thrown also by comparing it with 285 tire size, it still confirms that this is the logical choice (to go down from 295) as the offset is what it is.
      10-01-2018, 08:42 AM   #9
650GC
Hey, with your 255/35/20 at front and 285 30 20 in rear. Don't they have more than 1% of rolling diameter? any issues with transfer case? I know the OEM wheels had about 0.96% of rolling diameter difference which is still less than 1% but not close to 0 which they should have been for transfer case to last longer.
      10-01-2018, 08:47 AM   #10
Chili Palmer
Master Of My Domain
My car is a non-X, rear wheel drive so no issues.
650GC14.50
      10-01-2018, 09:08 AM   #11
Chili Palmer
Master Of My Domain
M373:
M343
Nope, everything bolted right up - I did step down one tire size from the stock M5 set up being that the non-M cars have narrower front fenders and the rear axle must be not as wide by a few millimeters on the M's. 255/35 in front and 285/30 in the rear. But the fronts are freaking close to the brake caliper assembly, but they clear so no worries. On the 5 series cars built after the 2012 model year BMW changed the front brake calipers and a spacer was needed to clear. I was hoping that wasn't the issue on the 6's being that my car is 2015. I actually forgot about that when I installed them, it wasn't until I had all the wheel lugs torqued I remembered that. I quickly jacked up the front and spun the wheels and they turned freely. Whew!
FBMWWINS603.50
      10-01-2018, 09:18 AM   #12
FBMWWINS
FBMWWINS's Avatar
604
Thanks.
Mine is an Xdrive don't know if that makes a decisive difference..... I am still hesitating now I also like the M668 wheels from the new G-30 as well. I am looking for some wheels where no mod is necessary but want to stay original BMW.
650GC14.50
      10-01-2018, 12:50 PM   #13
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
If the tire poke out you could go with a slight negative camber on the back. Than the tire will fit under the fender during compression without modding it.
FBMWWINS603.50
650GC14.50
      10-01-2018, 03:14 PM   #14
jjasonSU
Drives: 650i, NSX
Looks nice.
the "rotary forged" actual weight reduction is interesting.
650GC14.50
      10-01-2018, 05:52 PM   #15
DerBosewicht
Problem Solver
DerBosewicht's Avatar
Drives: 640i Gran Coupe
Thanks.
I have xdrive I ran a diff setup, but 245/35/20 285/30/20 is the closest you can get the 255 295 is within the range also but the rev per minute was the deciding factor for me
255/35/20 & 295/30/20
Vs 245/35/20 285/30/20
Those are a very good look... like em a lot!
You need people like me so you can point your f*ckin' fingers and say,
"That's the bad guy".
"Das ist der Bösewicht".
650GC14.50
      10-01-2018, 08:29 PM   #16
Chili Palmer
Master Of My Domain
Negative camber? This is a finely tuned Euro-tourer, "the ultimate driving machine", not a ghettoed out Honda Civic. If I'm going to stuff 295's under my rear fenders, I'm going to use the proper spec'd wheel to make it look like it's made for it.
I don't mean to seem harsh, but I didn't expect a solution like that.
      10-01-2018, 09:18 PM   #17
board57796
Looks nice! I was considering 11” rears but went with 10.5” on 295/30/20s
      10-02-2018, 06:29 AM   #18
650GC
Looking nice, are those forged? How much do they weigh and what offset did you go with.
      10-02-2018, 08:01 AM   #19
board57796
Thank you! They’re like yours, rotary forged. Honestly I don’t know how much of that term is just marketing schtick, but my tire guy said he couldn’t believe how heavy the OEM wheels felt compared to my new ones so maybe it’s legit.
Mine are 20x9 ET 35 and 20x10.5 ET 42.
650GC14.50
      10-02-2018, 10:58 AM   #20
Chili Palmer
Master Of My Domain
Looking good!
      10-02-2018, 11:08 AM   #21
board57796
Looking good!
Thank you! Yours too
      10-02-2018, 11:11 AM   #22
Chili Palmer
Master Of My Domain
I've still got to get my front splitter, rear diffuser, trunk spoiler, and M6 exhaust installed, they're all sitting in the garage. Hopefully in the next couple of weeks.
