02-04-2021, 08:02 AM | #1 |
Mad Fiddler
792
Rep 991
Brake Fluid
Finally got the brake fluid flushed. I feel a big difference. Less pedal travel, more consistent feel. And now the car is being much less of a pain in the ass. The reminders were getting on my nerves. I got them from the car every time I started it, several emails from BMW and also the dealer reminding me, reminding me, reminding me.
08-29-2022, 07:46 AM | #3 | |
Mad Fiddler
792
Rep 991
https://slautoworks.com/bmw-repair/bmw-brake-flush/ |
08-29-2022, 08:48 AM | #4 |
Rep 2,906
2 years is the recommend interval on most all cars. The reason is not because the fluid wears out per se, but because brake fluid absorbs moisture, which lowers its boiling point and corrodes internal brake components. But I have never noticed any difference in braking after a flush. You may have had some air in your lines.
Frupal791.50 |
08-29-2022, 09:12 PM | #5 |
Rep 628
There is also a cheap brake fluid moister meter you can buy on Amazon. I use it to check my brake fluid periodically since sometimes I do not use the car for an extended period. Humidity is high here in Houston, so it is worthwhile to double check it once and while/
F06 M6 Grand Coupe CP
Frupal791.50 |
08-30-2022, 12:06 AM | #6 | |
Rep 7,468
If there’s a green “OK” next to the listed service…then the service isn’t due for a while. If there’s an AMBER symbol next to the service…then the service is coming due and you’ll see the month/year and mileage the service will be due. If there’s a RED symbol next to the service…then the service is OVEWRDUE and the month/year is shown when it was due.
Frupal791.50 |
