02-22-2020, 09:33 PM | #1 |
Rep 3
Question abt m6 m-performance exhaust
My 2017 M6 with competition pkg. and with factory full titanium Mperformance exhaust. I would like to ECU stage 2 on my car recently. My question if the downpipe is titanium or just regular normal downpipe? is it necessary to upgrade downpipes in my case?
thanks guys
keep leaning
02-22-2020, 11:00 PM | #2 |
Rep 582
There not titanium ,there regular catted downpipes, Its not necessary to upgrade unless you want more sound you can go catless downpipes, stage 2 you have to gap your spark plugs .020
02-22-2020, 11:30 PM | #3 |
Rep 3
Thanks for letting me know,
keep leaning
02-23-2020, 10:26 AM | #4 |
Rep 84
02-23-2020, 10:01 PM | #5 |
Rep 582
Some company’s stages are different than others , ex. DME tuning has 3 stages stage 1 is just tune with significant pump in power , stage 2 is more power than stage 1 but requires gapped or colder plugs on 91 octane , Stage 3 requires gapped or colder plugs and must use 93 octane for a higher bump in power , none of these stages require catless downpipes, if intakes and downpipes were added later the DME will compensate and add the extra power and throttle response so no follow up tune is needed but you will want cold start removed if you went catless , cold starts are brutally loud .
Now you can go above and beyond with upgraded turbos , meth injection, upgraded clutch and supported rear with axles and driveshaft , I’m not sure what stage these would be considered, some companies have packages with there own set stages. |
HeyKC101.50 |
02-23-2020, 11:54 PM | #6 | |
Rep 3
keep leaning
02-24-2020, 08:31 PM | #7 | |
Rep 582
Im not sure how a wide body kit will affect performance but im sure its big money if you go with a legit kit and professional install, check out imsixxi on instagram I believe his kit is by PSM
