      09-01-2016, 06:38 AM   #23
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Originally Posted by speedracerlo View Post
Here's a recent photo taken by my SA at McKenna BMW
I have the KW HAS kit installed to
t
Do you have any front quarter shots or down the side? It's hard to see the wheel position relative to the wheel arch / fender in that photo.
Thanks!
I have -20mm lowered eibach springs on my M6GC and want to judge which spacer width to go for.
      09-01-2016, 07:43 AM   #24
IM6
Drives: BMW M6 F13
I have a vibration issue above 100mph, we are going through raft of things in eliminating factors. still no luck, need to try without spacers.
      09-05-2016, 12:19 AM   #25
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Originally Posted by Giggity View Post
M6-Coupe, Are you running spacers on your M6 with the OEM wheels? Sizes?
Anyone else running spacers on an M6 with OEM?
Running 15mm spacers all around on OEM wheels.
Full Vorsteiner Aero Kit, ADV5.0 M.V2 CS rims, KW HAS kit, M Performance Exhaust w/ CF tips, CF Mirror Caps, CF Gear Selector Lever, CF Side Marker Gills, CF Front Grill, Dinan CF Intake, AFE CF Engine Cover, Stage II Dinan Tune, Exhaustmeister, Internal Escort 9500ci + Laser Shifters, Photosync window tint 65% windshield 35% windows, Full PPF xpel ultimate wrap, RK Autowerks noncatted DPs, reflector delete, various coding
      09-05-2016, 01:14 AM   #26
JDM_M6
Drives: M6
Anyone know of other BMW model spacers will work? I have ones for the previous model 5 series but checking online, the current 6 series don't come up as a match.
Surely all 120pcd spacers are the same??
      09-05-2016, 02:16 AM   #27
doughboy
doughboy's Avatar
1545
No, BMW use different hub spigot diameters on different models. You have to get spacers to fit a 72.6mm hub. Any smaller it won't fit and any larger it won't centre.
E9x 3 series are 72.6mm, amongst others, my spacers are from my old 335i.
You'll need extended bolts and the M5/6 uses M14x1.25 thread, most other BMW are M12x1.5 so won't fit. The new bolts and locking bolts cost me more than the spacers!
      09-05-2016, 02:24 AM   #28
doughboy
doughboy's Avatar
1545
Any pictures kris1858? Much appreciated!
      09-05-2016, 03:06 AM   #29
JDM_M6
Drives: M6
Thank you!
      09-05-2016, 08:54 PM   #30
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Here are some pictures. Hopefully they are what you need. I think it looks aggressive but not overdone.
      09-05-2016, 08:57 PM   #31
speedracerlo
Drives: 2015 M6 Gran Coupe
Thanks!
here
I didn't know eibach makes springs for the M6 now
      09-06-2016, 02:08 AM   #32
doughboy
doughboy's Avatar
1545
Thanks guys, appreciate the photos, both great looking cars!
I think the 15mm is a little too aggressive for me, but the 10mm looks just right and I have a GC also with the same wheels.
The eibach springs are on the UK/Europe website but not on the US one...strange.
http://www.eibachshop.co.uk/eibach-p...m#.V85q3JgrJi8
But If I had my time again I would have bought the AC schnitzer springs, better ride.
      09-08-2016, 08:41 PM   #33
JDM_M6
Drives: M6
Could someone confirm what type of wheel nut is used for the M6?
Specifically the seating type?
      09-09-2016, 01:55 AM   #34
doughboy
doughboy's Avatar
1545
M14 x 1.25 thread
Black, 17mm hex head
60deg fixed taper / cone seat
Standard length 27mm (from thread tip to small end of seat)
http://www.realoem.com/bmw/enUS/show...diagId=36_1809
Part 3 for OE bolt
      09-09-2016, 08:15 AM   #35
JDM_M6
Drives: M6
Thanks Doughboy
      09-09-2016, 02:54 PM   #36
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
I use 12mm rear and 10mm front
      09-12-2016, 06:38 AM   #37
LI M6
Drives: 2014 M6 GC
+1
      09-12-2016, 08:15 AM   #38
XxTORONTOxX
Drives: BMW F13 M6
quick question boys, I still have my spacers from my e63 (645ci) will they work on my f13
      09-14-2016, 05:41 PM   #39
KauvSTi
Super Member
KauvSTi's Avatar
129
Drives: M6, M8 Comp, S63, 720S, F8
Looks damn good! Are you lowered?
DME Stage III, Catless Downpipes, SSP Basket & Clutches, 3.5" Custom Intakes & Eisenmann Race Exhaust
      09-14-2016, 08:05 PM   #40
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Thanks!
Nope, still on stock suspension. The vorsteiner CF aero kit gives it a lowered appearance.
      09-24-2016, 07:40 AM   #41
JDM_M6
Drives: M6
Just wanted to warn those thinking to do this. Make sure you get some quality spacers. I purchased a set of aluminum ones off eBay and narrowly avoided a disaster. Put them on myself and torqued. Did this in my carpark and left it overnight, next day I wanted to double check and all nuts were lose. I tighter then up and moved slightly and again they were loose. Did this a few times and decided not to take the car out. Just took the wheels off and the hub rings were snapped off!
I'm staying away from this spacer thing despite having done the same on my last 5 rides. I must be getting old and not a risk taker anymore....
      10-04-2016, 03:58 AM   #42
KSA.m6
Drives: M6 14 GC frozen grey & 21 M2C
  [0.00]
Originally Posted by LI M6 View Post
+1
just wanted to ask if you changed the bolts to a longer length or just kept the oem ones?
      10-04-2016, 04:29 AM   #43
doughboy
doughboy's Avatar
1545
You will need longer bolts for sure. Standard bolts won't even reach the hub through a 10mm spacer.
Extend bolts by same thickness as spacer if possible.
Standard m6 is 28mm, so 40mm is good for 10- 12mm spacers.
But 20 black bolts costs almost the same as the spacers.... most bolts are silver which looks terrible on a bmw.
      10-04-2016, 06:59 AM   #44
IM6
Drives: BMW M6 F13
with my 10mm spacers all round the stance looks so much better. but I have temporarily taken them off due to eliminating the vibrations issue.
