      05-04-2021, 10:17 PM   #1
CoffeeBean
Drives: 640i M-Sport GC
I might be beating a dead horse, but the info I've found is conflicting.
What's the general consensus on aftermarket tips that slide over and clamp on the stock muffler pipes on a 640? Absolutely nothing is labeled as being for a 640 so I'm having to go off the inlet size. Mine are 2.75" or 70mm without the stock tip. There isn't much to choose from in that size for sure. Any info and pics of ones that work?
      05-05-2021, 01:32 AM   #2
rasa bmw
https://www.aliexpress.com/item/3286...56964c4dSqh22D assuming you have same as my 640d,,,i got 63mm x101mm,need to cut old ones off around 3-4 inches,the pipe that is cut off tapers to 62 mm,,pull old tips off first as they are only clipped in
      05-05-2021, 01:35 AM   #3
rasa bmw
the 70mm tapers down to 62 mm
      05-05-2021, 03:52 AM   #4
Js640d
Drives: BMW 640d coupe
I got some carbon fibre ones for my 640d off eBay and they fit straight on. The old tips pull off and these slide on and bolt up tight. They look really nice and really improved the look. The inner diameter was 68-71 mm and they fit perfect.
The seller on eBay was Jasmia09 and I went for the shinny stainless steel inner with gloss carbon fibre outer. They also have the M logo etched on the top. Very pleased with them and the quality is great. Picture does not do it justice.
Cheers
Jim
      05-05-2021, 08:33 AM   #5
rasa bmw
i cut my pipe off as it would poke through the tip inner and be able to see it
      05-05-2021, 09:14 AM   #6
CoffeeBean
Cheers
Jim
That does look great and I prefer that style. I checked that seller, but they only had a few and not that particular one. I came across what appears to be an identical set (70mm inlet), but black on the inside. I figure that would kind of mask the inside pipe with it being black from soot too. I'd prefer not to do any cutting like rasa did.
https://www.ebay.com/itm/2-Pcs-Black....m46890.l49286
      05-05-2021, 10:24 AM   #7
Js640d
Yeah they are more or less the same. When you fit them your exhaust slides into the new tip which is sleeved so you do not see any of the original exhaust pipe. It is hard to explain but when it’s fitted it looks like a factory fitted item. If you look at the third from last picture in your link you can see where it slides into the inner sleeve of the tip. I am so pleased with the difference they made. I have taken a better picture of mine to help explain how they look.
Cheers
Jim
      05-05-2021, 10:34 AM   #8
CoffeeBean
Oh yeah I see how it's split inside so the pipe will slide under the "baffled" part. Even better. Yours looks great.
      05-05-2021, 10:46 AM   #9
Js640d
They do make a massive difference especially when they are clean haha. The old tips are easy to pull off with a bit of a wiggle and a tug. Took me ten minutes to fit mine.
Cheers
Jim
      05-06-2021, 01:36 AM   #10
rasa bmw
also,i wanted mine flush with rear diffuser,,so i woud have had to cut some off anyway..
      03-15-2022, 04:43 PM   #11
ex46fanatic
39
Im getting close to doing something about the wimpy rear end of the 640i.
Want to go with m6 diffuser and hopefully with these clampable 650i style tips below with an ID of 67mm.
https://www.ebay.co.uk/itm/281555149472
Please have a look, do you think i would be able to fit these to my 640i without cutting off the pipe? Would it stick out too much? Where exactly does the exhaust pipe terminate behind the diffuser?
I dont want to cut any pipework... want it to be reversible... Hence this route.
      03-16-2022, 06:20 PM   #12
ex46fanatic
39
https://www.aliexpress.com/item/33031556395.html
Have a look at this item as well. Im guessing the pipe will show in the middle if i fit something like this?
