07-10-2018, 04:19 PM | #1 |
Rep 659
Coding - E-Sys (HUD Blinkers)
so i downloaded the Virtual machine with esys installed earlier, got everything i wanted enabled
M Startup display Sport to display HP & Ft LBS mirrors folding at .5 seconds video in motion Video codecs from USb Bright Halos with lights legal disclaimers all removed & more but i just couldnt get the blinkers in HUD, has anyone manged to get this to work through esys or another program ?
Current: 2017 M6 Gran Coupe
07-10-2018, 07:25 PM | #2 |
Rep 28
Did you code the KOMBI or just the NBT? You need to have all three of these set and coded:
KOMBI => 3008 => HUD_PIA_BLINKER => aktiv KOMBI => 3000 => BLINKER_HUD_ENABLE => aktiv HU_NBT => 3001 => HUD_TURNSIGNAL => aktiv -Joe |
07-11-2018, 04:39 AM | #4 |
Rep 659
07-11-2018, 12:18 PM | #5 |
Rep 209
I was going to ask if you've got the digital cluster. I found a site ages ago that stated if you update to the latest firmware you can get blinkers in HUD. From memory it was the firmware of the HUD.
07-31-2018, 04:34 AM | #7 |
Rep 119
Got mine working in the hud along with phone and radio info too, coded using Carly.
Never used esys but sounds like ncs expert I used to use for my e46 M3 a few years back. |
07-31-2018, 02:35 PM | #8 |
Rep 28
Do you have the digital screen for your speedometer/tachometer though? I thought I remember reading that you can't do HUD turn signals with the 6WB digital cluster but it looks like there might be a solution in another thread through a post above.
2020 M8 Comp Coupe
07-31-2018, 03:16 PM | #9 |
Problem Solver
111
Rep 416
So Mark.. and definitely not to thread jack is it possible to upgrade 13’s to the digital cluster...? I have non digital and got it coded for blinkers to work in HUD..cool feature to enable
07-31-2018, 04:25 PM | #10 |
Rep 659
do you mean retro fitting a 6wb in a f13?
if yes ive not seen much for the 6's but the below was done on a 3 series https://f30.bimmerpost.com/forums/sh....php?t=1413357 imagine its not to different for a 6, dam expensive though £1300.00 i also didnt find anything regards the fimrware update vs HUD blinker
07-31-2018, 04:48 PM | #11 |
Rep 119
Ah, that'll be a no, I haven't.
07-31-2018, 05:10 PM | #12 |
Rep 28
That makes more sense, I also have the mostly analog cluster (6WA) and have activated HUD signals successfully. After further reading, it does not look like you can enable HUD turn signals in DKOMBI with the digital 6WB cluster sorry OP.
-Joe
2020 M8 Comp Coupe
07-31-2018, 05:13 PM | #13 |
The cars we drive say a lot about us.
49
Rep 148
i had my 2014 650i coded yesterday and the guy that was doing it told me that the blinkers cant be done if you have the digital screen. on my 2013 m6 it worked with no problem....of course no digital screen there
A bad day at the Racetrack beats a good day at the office
