      12-07-2019, 03:43 PM   #1
mediaboy
Drives: F06, F10, G07
Wireless charging installed
Just thought I'd drop a post in case anyone else was interested in adding clean wireless charging to your car.
Using this kit:
https://www.uspmotorsports.com/Inbay...-Coil-Kit.html
I removed the center console, pulled the plastic center out, cut a square hole and mounted with the supplied double sided tape.
I had to strip the kit down as well since there isn't much room. Fits perfect.
Rubber cover hides everything. You can't tell it's even there.
I just need to come up with an OEM style way of keeping the phone from sliding around. The rubber cover has ridges, so an anti-slide pad won't stick to it.
Hope it helps anyone looking.
