      04-11-2019, 04:13 PM   #1
night0
Drives: E92
19" wheel setup??
Anyone have any photos of their car with 19" setups? Looking for a meaty track setup!
      04-11-2019, 07:11 PM   #2
BMWDriverX
Drives: G12 750i X-Drive
Don't think 19's will clear the front brakes.
      04-11-2019, 07:13 PM   #3
Flying Ace
Flying Ace's Avatar
4985
M6 coupe came with OEM 19 wheels
      04-12-2019, 09:16 AM   #4
Qsilver7
Qsilver7's Avatar
Ditto...BMW wheel styles 344 & 408 are 19" wheels that were offered on the f06/f12/f13 M6 models & the f10 M5 model (Style 408).
      04-12-2019, 06:09 PM   #5
RagtagXMASTER
RagtagXMASTER's Avatar
119
Drives: 2013 M6
here is my car on 19s (433m) with michilin pilot super sports. The wheels have to be M6 spec to fit. the 650 wheels will not work. here is also the car on 20s (601m) also
      04-13-2019, 10:38 AM   #6
M6noah
Drives: M6 F13
2008 BMW 328xi  [0.00]
2010 BMW 328i  [10.00]
Nice M6, I might have seen you at a meet or two 😂
      04-20-2019, 05:25 PM   #7
Flying Ace
Flying Ace's Avatar
4985
I really like the beefy look of the OEM 344 19s. It's probably the only wheels I'll go with that fits the car and clears the calipers.
I wonder how it'll look on a GC
      04-22-2019, 08:00 AM   #8
RagtagXMASTER
119
Drives: 2013 M6
there are rep 344s that are 19s but will not clear the calipers, a local m6 to me tried and it does not clear the calipers sadly. the oem 20" 344s have no issue obviously.
If you do find rep 344s in 19s just be cautious for their fitment over the caliper, im sure there are plenty of different reps out there
      05-03-2019, 10:14 AM   #9
Rob@RBTurbo
Rob@RBTurbo's Avatar
Drives: '08 335I AT, '14 M6 DCT
Does anyone know if the OE 19" 344M rear wheels clear '14 M6 Coupe carbon ceramic rear brake calipers? I measured just about .6" clearance (on the radius) from the wheel to the caliper on the OE 20" 343M, so it is going to be a toss up and would prefer having someone who has actually attempted it already? Not concerned about the front fitments and this is only a rear wheel question here.
      05-03-2019, 03:26 PM   #10
Qsilver7
Qsilver7's Avatar
I don't have any physical experience but based on the part database...the 344 wheel style is not listed when you select YES for the S2NKA M Carbon ceramic brake option. If you select NO or ?...then #2 does appear: https://bimmercat.com/bmw/EN/search/...M6/USA/36_1731
If you click the link above...it will take you directly to the part database for the 344 wheel style...and item #2 is listed. But if you look at the upper right of the page and select for the ceramic brake option...you'll see that #2 is no longer listed...which means that the wheel doesn't fit if you have the ceramic brakes.
      05-03-2019, 03:40 PM   #11
Rob@RBTurbo
Thanks for the feedback. I'm afraid you are likely correct here, upon closer inspection it appears the clearance is closer to about .52" at some tighter points. So assuming the 343M is made to exact tolerances as the 344M (inner to inner diameter) my best guess is that they "may" still fit, but with ~ .5mm clearance it would be a bit of a risk and likely something that the OE's would never put their John Hancock on.
Rob
      05-04-2019, 02:05 AM   #12
Flying Ace
Flying Ace's Avatar
4985
Rob
That's too bad, because I'd love to see large brakes completely fill the wheel space.
